air in the box a4ld
Momohenri
Hogne Belgium
Ford Bronco II
Hello everyone, I added a radiator to cool the a4ld box more but now I have air that I hear brothed in the pump, how can I purge this air?
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
How are the lines oriented on your cooler? If theyre on the bottom that could cause air to get trapped in the system
Momohenri
Hogne Belgium
Ford Bronco II
original radiator the two pipes are connected below but the quer I added they are on the side horizontally
and the air we hear is in the box, probably in the pump
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Automatic transmissions don't need to be bled like brake or clutch lines. Air simply can't "get trapped". If the fluid is foamy with air bubbles in it, its overfilled.
Momohenri
Hogne Belgium
Ford Bronco II
additional information, when I remove the radiator hose and run the engine, there is only a small trickle of oil coming out, faulty pump or air bubble which prevents the oil from passing ?
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Check the fluid level first. Why was the cooler installed? Was the transmission having issues?
Brad
Momohenri
Hogne Belgium
Ford Bronco II
I do 4x4 with trailer to take out my firewood and the gearbox tends to heat up in these cases, that's why I put an additional radiator, the oil level is good, now I wonder if the oil was not heating due to poor circulation
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The pump provides the pressure to physically shift gears, if you didn't have proper pressure/flow the transmission wouldn't move.
8,370
As Dirtman said air can NOT be "trapped" in a transmission cooler
The Front Pump(only pump) sucks in ATF thru the filter in the Pan
It then sends that ATF thru the Valve body, ATF then goes out to be cooled
ATF flows thru the cooler, or coolers, and then back to the Pan
So unless the Pan fluid runs dry no air can be sucked in, and any air in the coolers would be pushed out on startup of the pump (engine starts)
Momohenri
Hogne Belgium
Ford Bronco II
I know that in theory the air cannot stay in the box, and my mechanic knows it too, however one hears it gurgling when I put the gases so there is something which prevents the air from leaving but what? ??
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
It is possible that the vent is clogged causing a hissing or bubbling noise. Does the transmission work? Aka... does it move and just makes an annoying gurgling noise, or is it completely inoperable?
8,370
+1 ^^^
Just FYI
On the A4LD(and 4R and 5R), the Lower cooler line on transmission is OUT to cooler(s), the Upper is Return to Pan
This shouldn't matter unless there is a leak that's also sucking in air
Momohenri
Hogne Belgium
Ford Bronco II
I have to let the engine run a bit before I can leave, after it works but it lacks power, I think it skates as soon as it forces
8,370
You have a transmission problem, not a cooler problem
Momohenri
Hogne Belgium
Ford Bronco II
you give me an idea RonD , i will search if there is not an air intake at a fitting, although there should be an oil leak but i will look anyway
