adjustable- height shocks?
enter_sandman
Illinois
Used to be on facebook, there was a group on there where some members were using spring loaded shocks, they resembled the old heavy-duty shock absorbers...
but they were better. seemed to incorporate some ride-height adjustment.
And someone there had even fabricated adjustment brackets and welded to the frame, to adjust the truck's ride height/drop even more.
Interesting stuff...anyone have info about this here? I'm no longer on FB so I can't access...thanks for any info
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
It sounds like your talking about coilovers.
Our trucks don't use coilovers from the factory, but for certain rangers there are weld-on kits so you can run them in the front. Relatively easy work to do if youre handy.
To have a true coilover setup in the rear is much more involved. Requires ditching the leaf springs for a 3 or 4 link setup, which I'm relatively sure is a big pita unless you want to get rid of the factory gas tank and go to a full cell, even then it's a lot of work. Pretty much the only people who go to a linked rear are building race trucks that need 20" of travel. The lowest of lowrider trucks would use a linked rear as well. The guys on bags or hydros.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I have seen a kit that has coils that slide over shocks, then depending on how you set the clamps it could affect ride height. I used to use them on the back, had them on all four shocks on my 88 but it sure rode rough. Im not sure if they still exist , Im sure it was some china made crap, I got mine either at meijers or autozone.
airbourneranger
67
Greensboro, North Carolina
4.0 SOHC
4/5
245/45-18 & 275/40-18
Tighten it until it snaps then back off a 1/4 turn
I have a set of QA1 coil overs on my Ranger. Part Number is GS401-10650-C. They fit and work great. Only for the front. Only for coil spring trucks.
