ac fan-fuse 27 pass comp keeps burning out
david ranger
curacao
ford ranger 2wd
Due to Eddo;'s remark I decided to unplug the AC compressor connector GRY/WHT+BLKbefore installing the external relay.
Now the fuse does not blow anymore.
Ofcourse I have no working AC.
Guess the short is in the compressor itself ?
david ranger
curacao
ford ranger 2wd
Found 2 vids covering a delaminating coil causing a short..
8,372
Problem is fuse 27 has no connection to AC clutch
AC Clutch is powered by fuse 25 in engine fuse box
AC Clutch relay is powered by PCM Relay and fuse 11 in engine fuse box
Fuse 27 is a "trigger voltage" so it was most likely being shorted to ground INSIDE the PCM, probably the black/yellow wire, its always a ground if AC pressure is OK
david ranger
curacao
ford ranger 2wd
RonD, you were right. Drove around 2 weeks with AC compressor clutch unplugged but then the fuse started blowing again.
So no easy fix by replacing the clutch coil and i have to install that external relay.
Has anyone the pin out diagram for easy location of wires (41,69 and 86) in the PCM bundle?
2005 3.0 V6
Cannot find it online.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
RonD is always right lol...the D is for Da man!
8,372
david ranger
curacao
ford ranger 2wd
Luckily FORD put the number at the first pin and last pin of each row (1~27, 28~52,etc) so that helped a lot.
Finally installed the external relay and problem solved.
Thanks guys for all the help. Greetings from a cold car in the HOT Caribbean!
8,372
Good work
Thanks for the update
david ranger
curacao
ford ranger 2wd
And the fuse blew again after 14 days.
So maybe there is another short circuit somewhere.
I changed the fuse and now it works again.
I am waiting for the clutch coil to clear customs due to a long delay.
It is a shame not to try it as i have the part already.
8,372
The 14days is odd
Yes, might as well change the coil, but its power comes from fuse 25 in engine fuse box, not 27 in cab fuse box
I would be tempted to use a 15amp fuse in place of the 10amp, just to see if its a direct short thats blowing the fuse not an amp draw issue, the wiring can handle 15amps, so no "smoke show" lol, but up to you
The Blend Door is also powered by this fuse 27, and it was a common failure on Fords, although can't say shorting out was a failure point, but its an electric motor so certainly could be the issue, drawing too many amps now and then
david ranger
curacao
ford ranger 2wd
Thanks. I will swap it out for a 15amp next time it blows.
8,372
Do you remember adjusting the TEMP knob at the time it might have blown, or does it pretty much stay on COLD all the time, lol
The TEMP knob controls the Blend Door
david ranger
curacao
ford ranger 2wd
Thanks Ron D.
I unplugged the blend door actuator a long time ago so that may not interfere anymore.
I tried 15 and 20 amps with no result.
They burn within minutes.
So i will change the coil. See what that does.
david ranger
curacao
ford ranger 2wd
I sold the car WITH the problem for the next owner.
Thank you guys for all the help.
It is really appreciated.
