AC clutch cycles on and off but doesn't stay engaged
paulydonuts
New hampshire
ranger 4.0l fx4
After fixing my blend door actuator then with the help of RonD fixing my vacuum lines that a mouse chewed i still cant get the AC to blow cold. every time the clutch engages intermittently in a cycle, it blows cold for a second then stops when it disengages. for that short time its engaged i get cold air. i know the system is holding refrigerant just wont stay engaged.
rubydist
869
Denver
Ford Ranger FX4
what is the ambient temperature?
paulydonuts
New hampshire
ranger 4.0l fx4
i checked that it was within range, i dont know if its a high or low pressure switch or relay. i tried the paperclip method with the relay it stays on but i dont know how to diagnose the actual issue without buying every part. I took bridges down for a living electrical was always a over my head :unsure:
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Typically with rapid clutch cycling... the system is low on a charge.
You must remember with cooler ambient temps... clutch on time will be shortened. This has everything to do with the pressure temperature relationship of refrigerant.
The only real way to know what going on is not to blast new parts at it... but to put a set of gauges on the system and see what's happening with pressures.
paulydonuts
New hampshire
ranger 4.0l fx4
hey ill do another test tomorrow and see what it reads. Thanks for the help i appreciate it.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
needs refrigerant., might be leaking at the o rings.
Might just be a bunk compressor....I had to got through a few to get a good one. Fourseasons brand sucks BTW.
gw33gp
Ham Radio Operator
549
Costa Mesa, CA
4.0 SOHC
33"
I just went through this, and it was a low freon charge. They told me both Schrader valves had a very slow leak, and this is a common problem. They said after checking pressure or charging, the spring in the Schrader valve sometimes does not get it sealed properly. They always use a tool to pull up on the stem after charging with freon.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
This! My HVAC buddy who helped me resurrect my ranger a/c emphasized how important the caps on the shreader valves are to protect them from leak damage...they are very sensitive and jus open exposure will mess em up
No members online now.
