? about K&N Panel Filter
MikeInIdaho
Mazda
OK so I just recently acquired an '06 b2300 and in the process of doing regular maintenance added the aforementioned filter. Now, when I gave the instructions a once-over it stated to use the provided gasket on the airbox lid for exploders and mountaineers but not for rangers/ b-series pickups. I followed the instructions as this warning was repeated a number of times and even printed in bold letters in one place.
Is there really any kind of difference between the airboxes for these models that would necessitate leaving the gasket out? I'm curious, as the instructions state that I'll cause damage to the engine, etc. just by using the gasket. Just want to make sure I'm not sucking any air past the filter, as i spend a great deal of time in the desert and it gets dusty as hell out here. Any insight would be greatly appreciated, thanks in advance
Bob Ayers
16
Durham, NC
The airfilter is the same size for the 2.3L, 3.0L, and 4.0L. The OEM filter will flow way more air than a 4.0L will pull, so it is way over designed for your 2.3L.
If you are worried about driving in dusty conditions, by all means go back to the OEM paper filter!!! The K&N filter will PASS way more dirt (and oil) than the OEM paper filter!! Matter of fact, K&N knows this, or they wouldn't have come out with the "Precharger Filter" for dusty conditions:
http://www.knfilters.com/wraps.htm
Bottom line, there is absolutely NO performance advantage to the K&N filter, only the potential to contaminate your MAF sensor, gum up your IAC valve, and throttle body, and put tons of Si in your crankcase!!! So, my insight to you is trash the K&N, and go back to the OEM paper filter (Motorcraft, Purolator, or Wix).
And check this out from the warranty section on K&N's website:
"K&N will not be responsible for any other expenses incurred by the customer under the terms of this warranty, nor shall it be responsible for any damages either consequential, special, contingent, or otherwise; or expenses or injury arising directly or indirectly from the use of the K&N Air Filter."
Ranger44
23
Illinois
FORD
4.0 OHV
Buy the nice house brand air filter for $5. You'll be golden.
MikeInIdaho
Mazda
Thanks for the advice you guys. Looks like there's about to be a (barely) used K&N filter for sale around here pretty soon...
Wicked_Sludge
43
Westport, WA
3-point-GO
bob, no offense, but you should tone down your anti-K&N bandwagon just a hair.
bob is absolutely right about there being no performance gains from a K&N (or any aftermarket) filter. hes also right on the point that over oiling the filter can damage your very expensive MAF sensor.
but there is no risk of damaging the engine by letting too much "dust" into the engine. K&N's are more than sufficient to filter out any potential engine damaging particles. i am speaking from experience. ive had a K&N panel filter in my ranger for over 30,000 miles, in a range of conditions from -10 degree muskeg roving, to spinning dohnuts on the sandy beach. ive even sucked water on one occasion (whoops). my MAF sensor, intake, TB, and all other downstream components are just as clean and oil-free as they were 30,000 miles ago when i cleaned them.
Ive had a K&N panel filter in my escort for about 20,000 miles, with the same excellent results :icon_thumby:
the only advantage to these filters is if you plan on keeping your truck long enough for the K&N's re-usability to pay for itself. if you live in extremely dusty conditions (and it sounds like you do), it could pay for itself quite quickly.
Bryan22
4
So-Cal babay
94 extd
94 2.3
as far as sealing it up goes, put a SMALL amount of grease on the sealing surface, this way if nothing else, you will have peice of mind that nothing will get past your filter.
MikeInIdaho
Mazda
Thanks again for the advice guys. Think I'll put a little sealing grease on the mating surfaces as suggested, as I definetly am a worry-wart about these kinds of things...
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
Also for a little more peace of mind, I have a total of almost 300,000 miles on two Rangers with K&N filters with no problems. They have served a lot of duty in dusty off-road desert conditions.
My first Ranger had had almost 200,000 miles on it when I sold it and the engine ran as good or better than it did new. Right before I sold it, I towed my race car with it on a 5,000 mile round trip and it never needed a drop of oil added to it. That truck now has way over 200,000 miles on it and is still running strong.
I have been using K&N filters on all my vehicles (5 of them now) since the early 1980s and have never had any problems related to using K&N filters on them.
As said before, no performance advantage from them but they can run a long time before needing to be cleaned and still flow well. I run up to 50,000 miles before cleaning, more often in very dusty conditions.
Bob Ayers
16
Durham, NC
Do a search on "dusted turbos", "hi Si in UOA", and "dirty MAF sensors" and see what you find!
There is NO WAY that the K&N will filter as well as the OEM filter, all you have to do is hold it up to a light source and see the holes in the filter media!!
The K&N filter was developed for off road races, Like Baja, the reason being the OEM filters would plug up with dust in no time, but not the case of the
K&Ns. Same amount of dust was flowing, so guess where it was going!!
And since you do agree there is NO performance advantage to a K&N why would you want to take a risk in the damage from one? Also think about why
K&N would put the disclaimer in their warranty.
Check out these TRS threads, especially posts from AllanD:
http://www.therangerstation.com/forums/showthread.php?t=20263
http://www.therangerstation.com/forums/showthread.php?t=21168
Bryan22
4
So-Cal babay
94 extd
94 2.3
That's why you oil the filter... whatever the filter dosen't keep from bypassing gets caught by the oil. look at a dirt bike. I just went through and read through those other threads, and we had a K&N setup in a 2000 and a 2001 ford f-250 7.3 liter diesels. one with 70,000 on the K&N(actually second he replaced the first one at 50,000) the other only with about 10,000 miles on the K&N... never a single problem. both trucks run fantastic.
Bob Ayers
16
Durham, NC
The filter comes pre-oiled........and it still passes a lot of dirt!!!!
I guess you missed this post by AllanD in the thread links I posted:
Yes, but the factory air filter setup IS a cold air setup.
Hell even the original 2.9 setup had the air intake behind the grille.
Yes there's a preheater tube but that tube is CLOSED OFF most of the time.
Eliminating it can get you into legal hot water in terms of emmissions laws.
My brother LOVES K&N filters.
He will NOT use them on his own vehicle.
You see he is a Ford Dealer mechanic.
K&N filters make him more hours and thus more money.
Especially on the turbo diesels
Ever seen a turbo diesel that's bee run behind a K&N?
It's fugly.
AD
Wicked_Sludge
43
Westport, WA
3-point-GO
im not denying that a paper filter filters better. but what research have you done that proves that a paper filter isnt overkill?
between me and gw33gp, we've got over 350,000 miles on K&N's with no problems. if you'd like, ill pull my MAF sensor off the ranger and VAF sensor off the escort and take pictures of them for you. they are clean and dust free (and the ranger spends a LOT of time on the beach these days):
ive had the "dirty" side of the airbox full of sand from spinning dohnuts on the beach, and still nothing harmful got into the engine.
ive never seen a failure caused by a properly employed K&N failing to stop harmful particles.
i HAVE seen a failure caused by a cheap paper filter that didnt fit the air box properly, thus failing to seal and allowing unfiltered air into the engine.
Bryan22
4
So-Cal babay
94 extd
94 2.3
nah i didn't miss those parts of the threads, i don't care what his brother said, i've seen K&Ns in ford diesels with absolutely no negative effects. both truck run perfect. the work truck that I used to drive has something close to 200,000 miles on it, still hauls anything ang gets 21 MPG on the highway. We drove it mostly in the highdeserts of california, where the dust blows pretty much all year round.
Wicked_Sludge
43
Westport, WA
3-point-GO
the biggest problem with the aftermarket K&N filters made for the deisels is the exposed filter element gets beat to hell in that crammed engine compartment. ive seen more physically damaged K&N's on ford deisels than anything else.
the few K&N panel filters ive seen on 7.3's and 6.0's have been just dandy.
Bryan22
4
So-Cal babay
94 extd
94 2.3
ya, the filter was just like the one in my 94 (square panell filter) except bigger, the worst problem we ever had was one day it was running like shit and we could not figure out what was going on. about 500 miles later I go to change oil, filter ECT... pull the K&N and find about 1/2 a sunday paper stuffed in the air box. lol.
