I believe it is counterclockwise. Turn it 1/2 turn at a time and check the shift point from 2nd to 3rd. With light throttle it should shift into 2nd around 12 to 15mph that is goverened pressure (mechanical governor) then it should shift into 3rd at around 35mph with medium throttle pressure that is modulated pressure. If your having 1-2 shift issues it is oil pressure related possible oil filter restriction or sticking governor.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
