A4ld interchangeable 88-89?
Kuper
16
I have an 88 2wd ranger with bad trans and a 89 2wd parts truck was wondering if I could just bolt that one in? Tag on 88’ 88GT-BAA. And 89’ 89GT-AAA anyone that knows I thank you in advance.
8,370
I think the 1988 would be a 3 wire model, this has to do with wiring on drivers side of trans and if trans has 1 or 2 solenoids on the valve body, you need the 2 solenoid model in 1989
Look here: https://www.explorerforum.com/forums/media/a4ld-specification-chart-from-transgo.39537/full
It lists 1985 to 1988 as the 2 wire(1 solenoid) and 1989 to 1994 as 3 wire(2 solenoids)
But I think Rangers got the 3 wire models in 1988
But have a look to be sure
If 1988 is the 2 wire model you could swap valve bodys to make it a 3 wire
Kuper
16
Ok thank you
Kuper
16
Does anyone have any tips separating shift linkage from bushings?
Junk Collector
Truck of Month
4,802
Rapid City SD
Pry bar and lube...they can be a bit of a pain.
ford4wd08
510
Alcoa, TN
2.8 V6
I believe the change to 3 wire with 2 solenoids was mid '87 with the A4LD.
Agree on the prybar to separate, they suck.
To put them back together I found a thread that showed how to use a socket and a carriage bolt and nut to push them back in. I'll have to see if I can dig it up.
Kuper
16
Yeah that’s what I figured I will have to find out a way to not bend the bracket. I was trying to make a pickle fork out of scrap to remove and my crude attempt did not work. The donor I have is a column shift whereas my truck is a floor shifter that may be a problem.
Kuper
16
Well the pry bars were not working too well I made a couple of make shift tools out of what I had. I would suggest a long chisel with an opening big enough for linkage that would work better. Harbor freight stuff so no worries.
Kuper
16
I think I might be in business my 88 has 3 wire. I just need to inspect the 89 trans and if good swap the linkage off 88 on to 89 trans. Also saved some money making a transmission attachment from scrap I had.
Kuper
16
Well turned out the parts truck transmission wasn’t in the best shape so I had the original rebuilt.
