A Pinging Problem with a possible solution... HELP
scottsdale
Ive been running 91 octane the last 5 or 6 tanks and the pinging is pretty much gone... Ill try switching back to the regular 87 octane for a few tanks and see what happens. And change that dam timing chain when I get the time to see of that helps.... its got 107,000 on it now so its proabably time
I also read somewhere that a guy took his truck in (to the stealership) for an oil change and they did a PCM update... free of charge. They were talking about how this is usually the case when you take your car to a dealership for service its just something the dealer does. He had already replaced just about everything to try and fix the pinging, without fixing it, and after the PCM update the pinging was gone... Im going to take mine in to the dealer to have the speedometer reset after i get my 32's so I might as well ask about a PCM update while im there... what do you guys think? :dunno:
06RangerXLT
54
Georgetown Ontario
worth a shot. gonna take mine in soon enough for service. i need a trans flush, but every dealer around here has retards working for them.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
My 97 3.0L pinged like crazy when I bought it. I updated the PCM just because I can, it made no difference. I ended up running 3 cans of tune up/combustion chamber cleaner through it and drove the wheels off it. No more pinging and no need for anything other than 87 octane fuel. Carbon build up from babying these engines is the biggest issue.
06RangerXLT
54
Georgetown Ontario
what brand? im gonna run some through mine to help keep it clean
scottsdale
yeah ill sea foam the crap out of it next time i change the oil. I did it last time and it helped a little but it came back. I do drive it like a grandpa though
06RangerXLT
54
Georgetown Ontario
i give mine a good beating every so often. only fearful of the trans blowing, other then that its bulletproof.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Since I work at a dealership, I used Motorcraft!
Either the one in the aerosol can or the bottle is fine.
McCormack
8
Install a 180* t-stat and see if that helps (it usually does), and if that doesn't completely fix it then buy a tuner and retard your timing a degree or two and your pinging problem will be solved.
