- Sep 21, 2007
- 713
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 32"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
@kxri318 ,
The only time I've ever seen a 2.9l run rough, it had experienced a head gasket/head or lower intake manifold gasket failure, permitting coolant into the oil.
The only times I've ever seen one stall, it was either an automatic with a failed torque converter or had been driven with a compromised head or coolant leaking into engine by some means.
If misfires I would pursue the fuel system if timing is correct.
If it were only hi idle, I would chase vacuum lines.
SOLVE these issues CONCLUSIVELY, one at a time. I would follow this order:
1) stalling
2) misfire
3) hi idle
Do one thing correctly, then move to the next. Unfortunately, thing don't always fail one at a time and sometimes one failure will usher in another![Neutral face :neutral_face: 😐](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f610.png)
1) stalling
2) misfire
3) hi idle
