Auro4ba
- Mar 2, 2021
- 3
- Florida
- Ford ranger
Hey guys, I’m getting a little frustrated because I’m trying to help out a friend and I’m doing much more than anticipated... The truck is a 1997 Ranger with a 2.3L M/t 2wd. My problem is this. I began by throwing a P0340 (cam position sensor) and P0102I (MAF). That being said, I can start the truck just fine every time, then it will immediately stall. It will run smooth as long as I hold my foot on the gas. That is what puzzles me. After reading this if you have any ideas please let me know.
What I’ve done
Motorcraft plugs, wires, PCV, fuel filter, air filter, ignition coils, cam sensor (and required it due to exposed wire) serpentine belt, removed and cleaned MAF with MAF cleaner, and IACV with throttle body cleaner, as well as the throttle body.
If now only throws a P0102 and no longer a P0340. When I started it would run a bit rough while I pressed the gas and now having fixed the cam sensor issue it runs smooth. The problem still exists with the truck shutting off as soon as I take my foot off the gas pedal. Any ideas?
What I’ve done
