95 ranger front abs sensor, help asap, middle of job
Shotokan1509
CT
My apologies on cluttering the general board with a specific question but I'm stuck. Got the spindle bolts off, but the abs sensor is in the way. I took the bolt off the back of the electrical connector, how do I get the sensor to slide back? Can I push from the outboard side or will I ruin the sensor? Second, how do I get the block around the sensor off the outside of the spindle? I see a small bolt, but its completely round from rust. :pissedoff: :temper:
Bill
898
Sacramento, CA
It slides out. Sometimes they are a little difficult to get out due to the road grime that "glues" them in there.
Shotokan1509
CT
Do I have to pull from the back, or can I give it some oomph from the front (disc side)? Pretty difficult to get my fingers, let alone a pair of pliers in there from the back with the axle ears in teh way.
EDIT: And does that lower bolt have to be out before the sensor will slide back? or is that just holding that block on the front? It would be easier to work on that round bolt if I can get the sensor out of the way.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
There is another bolt that holds on that "Shield" (chunk of metal)
It isn't "round" from rust it's round because it is nearly round it's a 6mm 12point head
and you need a long necked deep socket to get the little bugger off.
Either that or a cheap 6mm deep socket that you don't care about that you can drive on with a hammer and half expect to throw away.
AD
AD
Shotokan1509
CT
AD
AD
:annoyed: 6mm 6point is what I started with and it didn't need a hammer. I guess I'll need to try to find a 6mm bolt out, because I doubt I can get enough room to hammer a 5mm on there. Does that shield need to come off before the sensor will slide out?
AllanD
135
1987... sorta
'93 4.0
I have never in 30-odd attempts to do so succeded in getting one
of those front wheel ABS sensors out without resorting to "extreme means"
In this case "extreme means" is a really big taper punch and a BFH to drive it with
and the sensor comes out in pieces.
this is why I suggested doing proper diagnosis before disassembling ANYTHING in
the ABS system
the problem is that the front sensor outer shell is stainless steel
and the steering knuckle rusts it into place, ass the knuckle rusts
it swells and the flakey swollen rust locks the tubular body into
the sensor so firmly that the bolt becomes irrelevant.
AD
