Tractor Dan
- Dec 29, 2008
- 1
- Near Lima, Ohio
- Ford
- Engine Size
- 3.0
Doing rotors,pads,and calipers on my dads 95 grand voyager it's a 2wd. I'm noticing the positive camber on the drivers side is getting worse. It still steers fine and is drivable but it's enough to wear the inside edge of the tire more then the outside edge. So my question is on a set up like that when it comes to alignment what do they adjust? Appears to be there is only tie rods to adjust. Either way it's going to a shop to have the alignment done i was just more curious then anything. He does need new struts but that's the next project on the list. I was more concerned about his brakes. Apparently he feels it's not important to tell me they are reallly griding. Pull the inside pad off the drivers side and all there is left is metal backing plate. No pad material. I think for now though on the tires to try and encourage even wear i'm gonna swap the one from the drivers side over to the passenger side front and the passenger side front over to the drivers side. He is looking at needing tires in the next 6 to 12 months so figure wear these out and get the alignment done all at one time.
