2.3L ('83-'97) 94 Mazda 2300 with 91 Ranger 2.3 enging compatibility
Lee Harrison
Cross Junction Va
Mazda B2300
I have a pretty nice 94 Mazda B2300 that has 220k and low compression on one cylinder. I would like to know if 2.3 out of 91 Ranger will swap without too much trouble. I have both complete trucks. Both are 2wd. Ranger has an automatic . Mazda is a 5 speed. Thanks for any info.
8,374
Welcome to TRS :)
Yes, 1989-1994 used the same 2.3l SOHC model engine, 1988 and earlier were different and 1995-1997 were different
You will need to swap the 1994 flywheel over to the 1991 engine and the Block plate(thin metal plate between engine and bell housing)
Use the 1994 starter motor
Good idea to change the rear main seal while any engine is out, cheap part but hard to get at if/when it leaks
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,819
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Just remember to remove the automatic wire harness from the donor engine and install your original harness. On some vehicles, that matters since the connection(s) back to the transmission will be different.
scotts90ranger
4,512
Dayton Oregon
2.3 Turbo
Yeah, there are other differences too as 2.3L's with autos don't have EGR and the coil mount moved around I think every year and I think '92 the alternator moved to the other side? If you have them side by side though you can just change what's different, if it looks the same it likely is.
Lee Harrison
Cross Junction Va
Mazda B2300
Welcome to TRS :)
Thanks a lot.
scotts90ranger
4,512
Dayton Oregon
2.3 Turbo
The auto crankshaft likely does not have a pilot bearing installed either so you will need to drive on of those into the back of the crank when you swap the flywheel on.
sgtsandman
12,819
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Good point.
Lee Harrison
Cross Junction Va
Mazda B2300
Oh yeah. That's right Thank you.
