FEandGoingBroke
- May 9, 2018
- 2
- Ford
Indeed I did begin by checking the overall health of the engine discovered a water leak repaired that.Let's just take a deep breath gents...
@2011Supercab sometimes it's just better to not say anything at all.
@FEandGoingBroke sometimes it's good to start from the beginning and inspect the overall health of the engine by running a full blown compression test. At least you will know the heath of things before going further.
I just have a simple question... what spark plugs did you put in it?
Changed old plugs at that time
Wires are 300 miles old, Belden top of the line, excellent fitment, ohmed out perfectly, no loose tips.
Great start up and idle, great free revving.
Smooth acceleration under 1/2” of pedal travel.
Choppy acceleration at anything more.
Coolant temp sensor for gauge was weepy and gauge was inconsistent, replaced with new.
Crank sensor, oily and ugly and old and oh hell sure it could be intermittent, it’s simply a winding of copper wire and a magnet, maybe it was failing, and at 19 or 20 bucks, why not?! No change.
Coolant temp sensor for ecm was sometimes off and gave rich idle when warm as it’s attitude decided, changed out with new.
TPS sensors that fail generally behave this way, replaced with new. (Still under 120 bucks for parts and all the gaskets I replaced)
after all that I came here to pick brains.
furthermore, fuel pressure as explained above operating out of book range when running, also under initial pump up koeo specs within one psi on the low side of book range, thus the new fuel pump. Same results, warranty replacement pump next day, same results with pressure and runability.
Onward to new pressure regulator, more positive results but not by one or two psi. Details five posts ago.
(a gentleman here in the forum suggested these 4.0 motors will still run decent as low as 20 psi)
The only items not replaced as per “runability” are the MAF sensor which is performing exactly to specs as per running tests, and the ECM, which had crap capacitors that I cleanly and diligently also replaced, all to the same results. So the ecm could still be the culprit, but testing it is a skill I have no awares about not a procedure to follow.
Since my TPS is under warranty I’m replacing it tomorrow. Same with the $92 dollar fuel pressure regulator.
I am at my wits end, thus I throw my self on the mercy of your experience and thoughts. I simply could have missed something totally novice but I can’t think of it. So I shall not take offense Any longer at suggestions and perform every test available and suggested by Y’all…. Without producing an attitude! (Probably)
Warm regards,
Gary
