jcook100
- Apr 5, 2019
- 10
- Salt Lake City, UT
- Ford Ranger
Hello there,
I am new and hopefully follow protocol here. I have a new-to-me 1991 2WD Ranger (4.0) with 9 in drum brakes. I am currently replacing them and have 2 questions.
1) I was surprised and disappointed when pulling off the drums to find that some of the interior parts were incorrectly placed or the wrong size. For instance, the adjuster cables on both sides were too long and just hanging freely in there. I was able to confirm at the auto parts store that they were in fact the 10" size adjuster cables, even though I definitely have the 9" brakes. Since I was unable to follow what was already in there (one side had the pads switched too), I had to do my best with diagrams online and the Haynes manual that I have, whose pictures must be for a slightly different model. Since there are 3 sets of 2 springs (3 colors), am I correct that one spring of each color goes on each side? Can anyone confirm that I have attached them correctly? (see picture)
2) I made the rookie mistake of pressing on the brake after fitting and bleeding the system WITHOUT the drum on. I blew one of the pistons out of the cylinder. I tried putting everything back together, readjusted, re-bled the system, and tested again but with the drum on. This time, the same cylinder failed but did not spit out the piston. My question is, can I reuse the same cylinder if the piston pops out? If I can, any idea why it failed on me when I tried it?
Thanks!
Thanks!
