2.3L ('83-'97) 89 Ranger electrical problem
Steve1950
san diego
ford ranger
89 Ford Ranger; no brake lights turn signals or flashers. I pulled flasher unit out probed for 12v no 12v with engine off. I am assuming one of the contacts should have 12v so flahers can work when vehicle is not running. I don't get 12v with engine off. Start the truck up and I get 12v to the flasher unit. That just doesn't seem right to me. I have a generic wiring diagram and it says hot at all times to the flasher unit.
Also my generic wiring diagram shows the same hot or 12v going to brake light switch. So I check for 12v at brake light switch. Guess what, 12v just like it is supposed to have and depress brake pedal and 12v passes to other wire. Brake lights flashers and turn signals still don't work. Not surprised I didn't fix anything. Looking at the wiring diagram it looks like everything passes through steering column multifunction switch. I suspect this switch is bad. Before I go through the trouble of replacing that switch anyone have any ideas? The 12v at flasher only when running has me baffelled. I changed the multifunction switch several years ago so maybe my part failed.
8,372
1989 will have 2 flashers, one for turn and one for 4-way, the 4-way has full time 12volts, I think its on the back of fuse box, turn is on the front
So no turns on dash or front, they use a separate wire than the rear turns
And is there a 3rd brake light on cab in 1989?
If so does it work?
Here is a 1990 turn hazard wiring diagram
The light green/orange(LG/O) and orange/light blue(O/LB) that run off to the right of the page go to the tail lights(brake/turn share 1 bulb on each side)
Outside of the 2 fuses the only thing these have in common is the Multi-function switch(turn signal stalk)
BlackBII
Ranger Custom
Truck of Month
983
UT
No third brake light on an '89
Steve1950
san diego
ford ranger
Thanks for the replys guys. The wiring diagram is better than the one I have. I will work on this problem when I have time. Definatly want to look at the fuse area and look for that other flasher. I will get back to you when I figure anything out.
Steve1950
san diego
ford ranger
Lossened up fuse panel to get a good look at the back. Nothing on the back side except wires coming in. Taking a closer look at one of the wiring diagrams I suspect possibly the flasher is bad. I am heading off to auto zone to get a heavy duty flasher. Wouldn't that be nice if that was the problem.
Steve1950
san diego
ford ranger
A new heavy duty flasher did not fix the problem. So I am trying to figure out the 12v flow through the fuse panel. On the back side of the fuse panel where all the wires come in I get a good solid 12v reading on the metal contact behind where the green with red stripe wire and the red with white stripe come in. No 12v on other side where flasher plugs in. Interesting I get 12v reading on the green with red stripe at the brake pedal switch. No 12v to flasher. Shouldn't 12v be present where the flasher plugs in??????? Niether of the wiring diagrams I have are correct, the both show 2 flashers this truck has only one. PS I checked for continuity rear lights to ground both sockets good. The attached photos are the fuse panel. IMG-0062 bottom left is where flasher plugs in. IMG-0066 back side of fuse panel. where the 3 wires wrap around that is the flasher corner. I can probe for 12v and get a good reading metal contact between the blue wire and the wires that wrap around the corner. It is just a metal contact on back side no wires where I get 12v. Voltage is not passing to the flasher plug in side.
BlackBII
Ranger Custom
Truck of Month
983
UT
Your fusebox doesn't have a second flasher on the backside, just opposite of the turn flasher? Is there a spot for it? That would be why they don't work.
This one should be accurate
BlackBII
Ranger Custom
Truck of Month
983
UT
The Turn flasher only has 12v when the key is on.
The Hazard flasher plugs in here:
Steve1950
san diego
ford ranger
:)SOOOO I will try plugging a flasher in the back side. I will give it a try
Steve1950
san diego
ford ranger
All works now. So I am new at this site. How do I give you points for your expert advice? Thanks
Steve1950
san diego
ford ranger
Here is a photo of the old Ranger you helped today. THANKS The photo is of the good side other side has some door jam damage no easy fix. My son bought this truck maybe 20 years ago. He lets me use it every once in a while.
Lots and lots of miles on the original 2.3. Tranny is a little newer, nice shifter.
8,372
Good work (y)
You can click on the "Like" link at the bottom of a post if you "liked it"
No members online now.
