when i connect the two bolts on the solenoid it sparks, when i turn the key nothing happens. radio and dash have power, new ignition switch, new solenoid, new starter(unless I damaged it when i jumped the solenoid and it wouldnt cut off until i disconnected the battery, this was about 30 to 45 seconds because i was not prepared for it, obviously i got a new solenoid after but i didnt swap the new starter because i didnt think this would cause damage but let me know if im wrong), tried starting while jumping the battery and making sure it was getting over 12.5V. , even tried bypassing the clutch pedal switch(if im doing it correctly)while battery was hooked up to another car. battery terminals are fairly new and clean, I even shaved some off and made sure connections are good, the wires for the grounds and the positive going to the starter seem intact and in good condition as far as I can tell.
