- Jan 12, 2021
- 827
- Walkerton Va 23177
- Ford Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
I have an 88 block and have installed new 89 style heads new manifolds etc I was planning to just remove the EGR components but the threads I can find state my 88 should not have had EGR yet mine most certainly does. Can I block it off and run the same ECU or will I have to get a newer ECU? Or should I just run it with the EGR on it. Planning to mostly trail ride and back road use of the truck. Will not be a primary vehicle at all. Any suggestions or direction is appreciated. Thanks.
