87 ford ranger will no longer start need help
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
So I finally did the ring gear on my 87 and got it running and driving but my clutch safety wasn’t working so I parked the truck to fix it and then I went to test it and it sounded like battery dying because it would slowly crank and the the solenoid click a bunch but I had it hooked to my full charged jump pack and if fiddled with it and changed the solenoid and now I have nothing it’s like push the clutch in and turn the key and everything dims but it doesn’t even click any ideas?
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Sounds like a combo. Weak or low battery and bad battery wiring connections. Remove and clean the ends on both positive and negative cables.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
I did clean all the connections and it’s got a fresh battery in it
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Have a multimeter? Check voltage of battery. At the very least should be 12.2V. A new battery will read 12.8V. If that's ok, then google "voltage drop test" and check the main battery wires.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
We’ll I put the old solenoid in and now it makes a clicking sound but the battery is charged and the jump pack is too
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Bad connection.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
We’ll I got it figured out. The battery cables were all messed up and broke also my starter was wire was grounding out on the block so replaced that and now it runs not good but it runs
