lost86broncoii
- Jun 4, 2009
- 1
- Baldwinsville, NY
1986
199
- Ford
- Engine Size
- 2.9,2.9,4.0
Hey just changed the plugs and cap on my ranger 2.9 auto the other day drove it home and it would barely make it up to 30mph sounded like death, so i figured i messed up the firing order, went out yesterday got some nice accel wires to go with new plug, cap, rotor. started fresh on the wiring from the best diagram i could get offline. now the truck won't start at all? pretty sure the firing order is set up right, but looking at the 86 bronco ii i have the two trucks distributors are at very different angles. What can I do to double check my firing order is right or could it be my timing is off bad and replacing all the new parts threw it off even more? trucks not starting, i got spark from the ignition wire, and fuels at the rail(although pressure seems weak and lacking)... thanks for the help, gotta get this truck running before dark :-/
when setting up the wires i used the screws in the distributor as my points of reference, is that right way or should i have just done it to the postition of the wires?
