85 bronco stalling in gear
Danny G
Michigan
Ford Bronco II
I recently purchased my 1985 bronco 2 and either when i shift it will either stall or if i ever come to a stop in drive or reverse it will stall with a little puff of smoke out the carb. Someone before me had a rochester carb on it so nothing from any other posts makes sense to me. Im not really sure where to start on this. Oldest thing ive worked on before this was an 87 corvette so my knowledge on earlier engines specifically carbureted is poor. Any help or ideas would be greatly appreciated. Im looking into an engine swap however id like to be able to drive it a little for the time being
franklin2
1,765
Virginia
If someone has monkeyed with the carb, it's a sure bet the original engine management system is all messed up.
I am assuming you have the original 2.8 v6? It originally had a computer system that ran the engine, same computer system that the fuel injected mustangs ran. The original carb had a fuel solenoid that the computer cycled to control the fueling, and it also had a dc servo motor to control the idle speed. The distributor didn't control the timing at all, that was done by the computer. The distributor has no centrifugal weights or vacuum advance on it to control the timing.
If you still have the original computer controlled distributor, it will have a module on the side of it and no vacuum advance. It's popular to get rid of this and put a older style distributor in place along with a normal carb. The older style distributor is getting harder to find though. You can get a normal carb that fits off Amazon or Ebay.
8,371
Yes, as said above in a 1985 there was a "feedback carb", and a computer that increased the idle when an automatic was shifted into gear
A little solenoid on the carb
Without that you will just need to set the idle higher than you may like so it won't stall in gear
Yes, check and reset spark timing as needed
Dustin_89BII
23
Oregon
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Did you get it straight Danny G?
Danny G
Michigan
Ford Bronco II
Ive been caught up with school and work and havent had the same time I used to to look at it. First time ive ever worked on a carbureted engine so im pretty much at a complete loss with no time to figure it out at the moment.
