5-speed Tranny Problem.
BayouGhost
Having trouble with my 1988 B2 transmission, it up-shifts fine, but can't hardly get it to down-shift! Had a clutch kit installed, but it still doesn't work right. Any suggestions of what I can check next, or do I just need a whole new transmission? Thanks for any help and advice!
Gary J
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Slave cylinder or its low on fluid maybe? Was the throw-out bearing replaced with the clutch?
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
def. check the fluid level/condition
sound like worn synchronizers. learn to double clutch if you won't want to buy parts
I'm with Brutus, the clutch kit wouldn't have fixed that unless it had a new slave in it. I'd put my money on worn synchros.
I wouldn't worry about it too much honestly. Downshifting isn't nearly as important as the upshift, unless you have brake issues, at which point you have other issues.
