- Jun 2, 2012
- 8,370
- canada
- Ford
You could probably lower the engine(pull motor mounts) and get front clearance
You need about 23" of clearance in the front to pull out and put in 302 cam
Put a LONG bolt on the end of cam shaft for leverage as the cam goes deeper, but not a tight bolt because you do need to remove with a free spinning cam, lol
You can put in a lifter to hold cam while removing the long bolt
You do need to be careful of pushing out bearings, should not be an issue, only use your hands, NO hammers
