- Aug 29, 2008
- 372
- Nevada
- Ford
- Engine Type
- V8
- Engine Size
- 5.0,4.0
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- 6”
- Tire Size
- 35
I’m running a 205 behind my ZF. They fit between the rails and are shorter than the 1356. Like Elutheros said, it’s recommended to add a crossmember and bracket to support the tail of the 205 due to its weight. They are a little noisy compared to the 1356’s though.
As far as a trans, you can use an 80’s AOD. I forget the exact range of years, but it’s an auto with overdrive and is vacuum controlled. A 4wd version came in F-150’s and Broncos.
