4.56 gears in a 7.5 with a lockrite
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Thanks for being my guinea pig... Im starting on mine this weekend after learning from all your mistakes. :icon_rofl:
It's funny 'cause its true!!!!! LMAO
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I just ran to harbor freight and stocked up on silicon carbide grinding wheels for my dremel. Waiting for my buddy to bring home my pinion depth tool and dial indicator. I don't have a dial indicating torque wrench so im a tad nervous doing the pinion pre-load but I think I can do it with a clicky style if I'm very carefull.
:icon_welder:
ericbphoto
Overlander in development
16,663
Wellford, SC
3.0L
6"
:icon_welder:
I used a beam style torque wrench. Just a few bucks at local auto parts store.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
So what I did for preload, is just get it tight enough to have a slight resistance when turning by hand. Inch lbs is very minimal and I use an inch lb torque driver at work for setting battery caps on our air packs. Basically 15 inch lbs is what you can tighten a screw to, using your thumb and index finger while pinching a screw driver handle with straight fingers, not having your fingers wrapped around the handle. If that makes sense.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I've never seen them in inch pound though. I have a beam style but it starts at like 20ft lb.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I have one... probably the least used torque wrench in my box. I bought it for a couple jobs and one of them was setting up rear ends.
60603
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
The one I have is a 1/4" drive, inch/lb. Only issue I had was I needed a 1/2" drive socket.
ericbphoto
16,663
Wellford, SC
3.0L
6"
Same here. I had to "reduce it up" to 1/2".
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Im searching the Amazon for one right now. Dial torque wrenches are just too damn expensive. I never thought beam styles existed that small so figured I was stuck using my clicky inch pound torque wrench and alot of prayers. Thanks for the heads up you non gender specific term for humanoids to which I show appreciation in a non threatening manner.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Mine is a Matco DR200-1
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
mine is intended for bicycles, small aluminum nuts.
problem is it takes 10 ft lbs to get the adapters moving! :icon_thumby:
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I have magical powers to make a pinion nut socket 1/4" drive without adapters.
