ok so i tried it again with no luck just a whole bunch of coolant on my driveway. (my driveway have a big slope in it) i just have no idea what is wrong if anything i forgot to mention that i cleaned the sensors while i had it apart with sand paper could that have made the sensor go bad? also could the rad cap have anything to do with this. i did notice when i did run it in my drive way that little bubbles were coming up from the over flow is this normal? the overflow never gets any fuller or any more empty at any engine temp
OK, guy, just how much coolant did you get into the radiator? My bet not any where near the specified amount.
The coolant in the radiator expands as it heats up. If the cooling system is full, the coolant expands and since it is liquid (and cannot be compressed) this extra coolant has to go someplace (that is why in days of old the radiator was never completely full).
So if the level in the overflow tank does not change it is because the radiator is not full. That is the bubbles you see. The coolant is expanding and forcing air out of the system. There can be two reasons the radiator is not full.
You didn't get it full!!! Or,
Compression gases are getting into the cooling system and pushing coolant out. If compression was pushing it out of a full radiator, the overflow tank would get full and then overflow (been there and done that). If it is trying to push it out of a less than full radiator it may not change.
If you haven't done it, do the glove test.
