4.0 SOHC Throttle body screws
Strider1833
Oregon
Recently got my 4 liter (2004) used from a private seller. Opened the hood to find that one of the screws holding the throttle body in place had a broken off head. So I removed TB and luckily I got the broken screw out with some vice grips. Of course now I need to replace that screw and I'm not having much luck. Tried ordering OEM hardware from ford and it was way off. (Couldn't find much specifics for the TB on this engine anyway) The screws I'm looking at have a particular thread pattern that doesn't seem too common. I've herd it called "hi-lo," and/or flanged. Heads are 8mm hex. I know better than to look for fasteners at auto parts shops, and my local hardware stores are clueless. Does anyone know where I could find these screws, or ones close enough? Maybe this is a question for a hardware forum, but any knowledge is much appreciated!
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,957
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If you are coming up dry with Ford and the other places, I would suggest a trip to the junkyard. Chances are very good you will find what you need and it will work.
Kira
62
Champlain + Hudson Valleys
Ford Ranger FX4
Get your hands on a metric tap & die set and determine what the thread size is.
Measure the length needed.
Go from there.
Ha, the 'hardware store' (industrial supply house, really) I'd send you to is 3,000 miles from Oregon.
Nice people in Oregon from my experience.
alwaysFlOoReD
5,197
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Take a bolt to your local bolt supply warehouse. Or directly to a ford parts service center.
Josh B
1,988
Oklahoma
If you can find a Ford CD manual for that year model, (must be branded by Ford) AND learn well enough how to search it you can likely find that screw, it's size AND part number
sgtsandman
Ham Radio Operator
12,957
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
They are a screw with a weird thread pitch for screwing into plastic without a threaded insert. Not surprising that he's having problems finding it.
SenorNoob
632
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Soo, wood screws it is... LOL
Seriously tho, junkyard may be your only hope.
Josh B
1,988
Oklahoma
Anybody got a photo of one?
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
...4 liter (2004
...one of the screws holding the throttle body in place had a broken off
...broken screw out with some vice grips
...thread pattern that doesn't seem too common...Heads are 8mm hex
Top view\pic below of ThrottleBody attached to Manifold, screws circled in red;
likely a German specialty flange screw, considering where engin was made.
Three possible solutions:
* HexHeadFlanged LagScrew from the Bolt+Nut isle of your local hardware store;
measure Thread diameter with a Caliper.
* Smaller diameter HexHead FlangeBolt or StandardBolt that fits thru existing holes;
add FlatWashers as needed, HexHead NyLocNuts on the backside; stainless preferred.
* a JY run to find an identical replacement from another Ranger\Explorer\SportTrac\...
A dab of AntiSieze\AxleGrease\Vaseline on the bolt threads & don't over tighten,
as a courtesy for the next poor bas'ard who needs to work on this vehicle+part.
Not sure if same is used on your 2004 V6~4.0~SOHC,
but the 2001 TB part# is 1L5u-9e926-ca, pic below.
