Junk Collector
Truck of Month
- Mar 4, 2008
- Reaction score
- 4,800
- Location
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
2.9 ECMs (actually, virtually all 1980's EFI computers) are very unsophisticated... the 2.9 batch fires its injectors and there's only two sets of them - each set of three fires at once. They all share a common power and ground. So to run two more... you just add another injector plug to each batch. For all the computer knows, nothing has changed - it still thinks it only has "two" injectors. Every other sensor on that era of Ford is more or less interchangeable, wired the same, and most even have the same plug... the programming in the computer itself and the clutch/auto trans wiring is the only major difference.Are you sure though guys have ran a 5.0 on a 2.9 ECM? How does the ECM deal with 2 more cylinders?
I'll be watching this thread, it's an interesting subject. I read on another forum this morning that 4.0 heads will fit a 2.9 block but you have to swap them from side to side, among other rumors. Hope someone can shed some light on this.
