4.0 Problems
Natedog
5
CA
Plug knock or pinging - There are several things that could be causing this. First off your MAF may be dirty. Check HERE on how to clean it. Then there are the obvious - plugs, wires, dirty injectors. Tune up items basically.
Check for loose lower intake manifold bolts. Pull your #5 plug and check it out. If you see the fuzzy head or have some oil present around the sides of the plug then bingo. The 93-94 have this problem VERY often. Usually you can fix it by simply tightening the bolts (in the PROPER sequence), but sometimes you need a new gasket. Do you notice a loss of oil with no leaks? Say 1-quart every 1500-3000 miles?
This is a simple fix...you will need the following:
1/4" Socket Drive
6" extension
Short wobble adapter (the broken neck socket adapter)
10mm socket
Follow the pictures below for the location and proper tightening sequence. Most should be able to solve the problem by simple tightening, but some may need to replace the entire gasket as it may be shot. Make sure you follow the sequence for tightening!
