C.Fuller305
- Jan 1, 2021
- 5
- South Carolina
- Ford Ranger
I have a 1994 Ford Ranger 4.0 V6 4X4 with the M5R1 Transmission. When I idle for long periods of time like sitting in a drive through my truck will cut off, also when I start it up in the morning after it has sat for a few hours I have to keep my foot on the gas for it to warm up because it will jump from 750 rpm to 2000 ish rpm then shut off. Just so everyone knows what has been done to it. New fuel pump, fuel filter, fuel pressure regulator, spark plugs, wires, MAF, O2 (2 of them), MAF wire plug, new ecu (yes the 200+ dollar computer is new), Head gaskets and up, air filter, Idle Air Control Valve is new, belt, idler and tensioner pulley. That is all that has been done to the engine all of my fuses and relays are good and have been double checked, however I do not have an EGR valve I'm not sure if it wasn't included from factory or if a previous owner removed it. the only thing that isn't exactly how it came from factory is my fuel pump relay the fuse box was giving me problems so I had to remove the wires and hook them straight onto the relay. They are in the correct order and each wire has shrink wrap and electrical tape to prevent a short.
