302 and T5 questions
19Walt93
4,502
Canaan,NH
351
3"
235/55R16
I just noticed your NH zip code. A 1999 vehicle under 8600 gvw needs to pass OBD II inspection by the Gordon Darby unit, an engine swap- even from a 99 or newer Explorer with all the emissions controls intact- will not pass because the VIN in the PCM has to match the registration. That's why I bought a 93 for my 351 swap. As for the transmission, I much prefer a T5 over an M5OD and the extra work to fabricate clutch actuation doesn't scare me a bit. Hurst has a work around for your bench seat, too.
75433
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I would just rent a car for prom and take my time on this project. One month is not very long, unless you are spending like 10+ hrs a day on this.
Anthony B22
03873
ford ranger 2wd
i have a driveshaft that mates with the T5 and the 8.8 with about 2 or so inches of “adjustability” before it bottoms out on the output of the T5, i want to say it’s an explorer driveshaft but it could be from the ranger, not sure. but it pairs to both so now the only question is length
Anthony B22
03873
ford ranger 2wd
this project has been in the works for 3+ months, it will be a rolling chassis by the end of this week i will post more photos but this has been in motion for a while and i’d really like to see it happen, i have a month to make the drivetrain function other then that everything else is mostly figured out
Anthony B22
03873
ford ranger 2wd
I just noticed your NH zip code. A 1999 vehicle under 8600 gvw needs to pass OBD II inspection by the Gordon Darby unit, an engine swap- even from a 99 or newer Explorer with all the emissions controls intact- will not pass because the VIN in the PCM has to match the registration. That's why I bought a 93 for my 351 swap. As for the transmission, I much prefer a T5 over an M5OD and the extra work to fabricate clutch actuation doesn't scare me a bit. Hurst has a work around for your bench seat, too.View attachment 75433
i’m using a carbureted engine there’s no ecm at all, i do like the idea of a bucket seat so this is my excuse lolll. i’m also on the same page about the clutch slave
19Walt93
4,502
Canaan,NH
351
3"
235/55R16
With no PCM at all it won't pass inspection, period. If a tech plugs the Gordon Darby unit into another vehicle to get an emissions pass code, he'll be able to generate a sticker but he'll end up at a DMV hearing and lose his inspection license. Please don't spend a bunch of money building a truck you won't be able to drive. I did state inspections from 1972 until 2017, I'm not trying to scare you, I'm trying to prevent you wasting money.
Anthony B22
03873
ford ranger 2wd
i’m not to worried about it, there always that once place that’ll lick and stick but cops in my area are pretty lax and she’s not gonna be driven too much
8,374
Looks like New Hampshire has a "rolling" year for passing emissions test, seen here: https://nhinspect.com/faq/
20 years and newer need to be tested and need to pass, so at this time 2002 Vehicles and newer need to pass OBD test
So 1999 shouldn't need to pass emissions test
Safety inspection is another thing, ALL vehicles regardless of year need this
What's inspected seen here: https://www.nh.gov/safety/divisions/dmv/registration/inspections-emissions/index.htm
It does list OBD system so not sure if that would be an issue if there is no OBD to inspect?
19Walt93
4,502
Canaan,NH
351
3"
235/55R16
I still have an inspection license and don't want to know who's operating like that. I wish you luck but I don't think it will fly.
franklin2
1,777
Virginia
Occasionally I will hear through the grapevine of a exceptional deal on a 4x4 truck. Then you find out it has a 6 inch lift on it. If it's too high it won't pass in Va either. Some young guy spent several of his pay checks online to put the lift and big tires on it, only to drive it for a few months and then learn it won't pass inspection.
Anthony B22
03873
ford ranger 2wd
i just looked it up and anything 20 years or older is emissions exempt
8,374
That's what I posted
But still needs an inspection, applies to any year vehicle, basically a "Road Worthy" certificate
Anthony B22
03873
ford ranger 2wd
yeah i mean she’s getting new everything, i don’t see how it could fault anything other then emissions.
8,374
In Calif I have heard/read some stories about V8s in vehicles that never had factory V8s
Mostly to do with frame and brakes because of the weight difference
289/302s tip the scales at 460lbs
The 4.0l OHV was at least 400lbs, 4.0l SOHC maybe 430lbs same frames as the 4cyls at 350lbs
But something about V6 vs V8 and weight that just sets peoples bells off, lol
Junglejoe
66
Columbia Missouri
6.0
Here is what I dine as well as others...
Get a Regar can 4 cyl driveshaft. Fits perfect on stock suspension.
Use Rick's swap plates with either the 3.0 or 4.0 ranger mounts. I also used Rick's transmission ccrossmember.You don't have to but it looks so.much better!!
Hydraulics for the t5....
1980(ish) 280 z slave. They say a 92 ford turbo probe slave works better.
2000 f550 clutch master. It does NOT just click in the bracket. The bracket has to be widened
