300 I6
CRAZ28
Roberts, Wisconsin
2.8
I like the swap, I drive an f-150 with the 300 and it pulls. It has the power, I put all the shingles from my roof into the back, truck weighed over 10,000 lbs on the scale, and drove like it had 1000 lbs in the back. (no overloads)
rusty ol ranger
2.9 Mafia-Don
7,809
Michigan
177 CID
I didnt see where he had to keep the stock intake.
In that case yes a EFI 300 would be best. They are capable of 3500-4000rpm, the 300 runs a 7 main bearing bottom end that will handle about all the RPM you can throw at it. Just gotta work the top end over to get it to breathe.
I never argued the 302 makes more peak power then the 300, but if you had a torque curve chart compare both engines at 1600RPM. Thats where the 300 shines.
500lbs is not a significant number anyways. Load both of them up untill one of them pukes and the 302 will be the loser, everytime.
Now, with a light load, (under 5000lbs) on flat ground, and with a stick shift, with 4.11 gears, the 302 would walk a 300.
But saddle both trucks with some weight, (say atleast a 8500LB trailer), some high gears (like 3.55's or even 3.08's), an automatic and a 4wd longbox truck and aim them up a hill, the 302's mustang roots will begin to show as the 300 is reminisent of a tractor, slow but never runs outta grunt.
later,
Dustin
