3.0 transmission
Jrez1
Pittsburgh pa
Ford ranger
I have a '99 ranger with the 3.0. Looking for an automatic transmission and what years will work with it. It is 4wd.
franklin2
1,775
Virginia
Bronco II
I am going to assume it's 2wd drive? Here are some hits from www.car-part.com in Pa.
999
Transmission Assembly
Mazda Pickup Not Rotary B3000
AT,3.0,TESTED GOOD,DROVE
X​
GG0324
$400​
Marsh Auto Salvage, Inc. USA-PA(Dawson) Request_Quote 724-529-0922 / 855-544-4367
110​
1999
X​
KK0640
$Call​
110​
2000
3.0 V6 C-AOD 2X4 4R44E
225,000​
C​
831
$400​
Hartlaub's Used Auto Parts USA-PA(Gettysburg) Request_Quote 717-637-1990
111​
2000
AT, 4x2,3.0,AUTO TRANS,RWD ***GOOD RUNNING TRUCK/HIT IN REAR/30 DAY WARRANTY***
91,000​
A​
14988
$500​
Ritenour & Sons Auto Wrecking USA-PA(Ellsworth) Request_Quote 1-724-239-2601
122​
2000
LOOKS LIKE PAST REMAN,TAGGED
X​
18M154
$525​
Toll Gate Auto Parts USA-PA(Greensburg) Request_Quote 724-834-5800
123​
FACTRY REMAN/$500CORE/3YR UNL.MILES
0​
AFT​
BAP14
$2512.25​
Chucks Auto Salvage #2 USA-PA(York) E-mail 717-628-3131 / 443-333-1411
144​
2WD TSTD. 5278
X​
SAM
$500​
Best Foreign Auto Salvage USA-PA(Aliquippa) E-mail 1-800-370-6002
159​
1999
174,000​
A​
2073
$400​
Don's Auto Salvage USA-PA(Beaver) Request_Quote 878-201-3144
166​
2000
A.T., 6-183 (3.0L), (4R44E), 4x2,3.0L,AUTO TRANS
227,000​
C​
T15005
$Call​
Tatko's Auto Salvage USA-PA(New-Brighton) Request_Quote 1-800-245-4447
167​
1999
XLT,3.0L,AT,RWD,T,C,D,Column
X​
18028
$200​
Sligo Auto Salvage USA-PA(Sligo) Request_Quote 814-745-3300 / 800-932-6424
175​
1999
-150K
X​
99RANGER
$350​
Route 65 Auto, Inc USA-PA(New-Castle) Request_Quote 1-724-652-7733 / 1-800-245-2226
181​
1999
3.0L,ATOD
0​
A​
V-343
$Call​
Cascade Auto Wrecking USA-PA(New-Castle) Request_Quote 724-654-1881
181​
2000
AT, 6-183 (3.0L), (4R44E/4R55E), 4x2
X​
20P0901
$475​
Patterson Auto Wrecking-RTN, MIDW, ARA USA-PA(Cochranton) Request_Quote 800-822-2028 / 814-425-7415
210​
2000
CORE, AT, 6-183 (3.0L), (4R44E/4R55E), 4x2-142K
142,000​
A​
19P0838
$77.77​
210​
2000
AT,3.0L,4-00
X​
190088
$Call​
Ed Spencer Auto-ELITE USA-PA(Berwick) Request_Quote 1-570-542-7700 / 1-866-603-7270
211​
1999
99 RANGER 4X2 AT TRANS 12/18/15 NOTE
X​
140431
$Call​
Andrews Auto Salvage USA-PA(Eldred) Request_Quote 814-225-4646
226​
2000
GOOD
X​
200383
$Call​
226​
2000
00 RANGER 4X2 AT GOOD TRANS 7/11/19
X​
190258
$Call​
8,374
+1 ^^^
Welcome to the forum
1999 3.0l Ranger used a 4R44E "MODEL" automatic, that's not what fits that's just the model
Like "Ranger" is a model, Ranger isn't specific, it can be a 2WD or 4x4, have a V6 or 4cyl engine, regular cab or extended cab, ect............4R44E is just the model number
3.0l, 2.5l, 2.3l 2WD and 4WD Rangers all used 4R44E "model"
You need a 3.0l "model" from a 1995 to 2000 3.0l Ranger or Mazda B3000, and as said above in 2WD or 4WD, that must match as well, no conversion is possible
Because you have a 1998-2000 Ranger you also have another "model" option, the 2001-2008 5R44E from a 3.0l Ranger or Mazda B3000
The 5R was the same transmission internally but had 2 added sensors on the outside, your 1999 doesn't need them so they don't need to be hooked up, so the 5R44E from a 3.0l is plug and play in your 1999 3.0l Ranger
And no, you don't get the 5th gear because there is no 5th gear, lol, it was just a software update in the 2001 and up computers
So you may find a lower mile 2001-2008 5R44E and certainly not as old as the 1995-2000 4Rs
Used automatics are a roll of the dice................
Always get a new torque converter when swapping or rebuilding any automatic
Also clean out the transmission cooler and lines
If old trans had metal filings they will be in the converter and cooler, and they will be transferred to replacement
franklin2
1,775
Virginia
Bronco II
As you can see in the list, there are no later model trannies. They may fit, but car-part usually only lists parts that plug and play. The later trannies may require a wiring plug change or some other simple modification to fit, but car-part doesn't include something like that in their list. They are a good interchange source to see what is a direct fit and what is not, though like everyone else they can have mistakes.
8,374
Yes, you would have to search for 2001 3.0l Ranger "2WD"?? and 5R44E, and would get the 2001-2008 autos available
2008 was last year for 3.0l engines
No difference in wiring for Ranger automatic transmissions, 1995 to 2011, the 5Rs from 2001 and up just has 2 extra sensors on the outside, using separate wiring added in 2001
