2019 Ranger Ecoboost Oil Change Interval
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
2.3 Turbo, 350, 5.0 HO
Stock, about a foot, about a foot
LT 265/65 R17, P285/70R15 & P195/65R15, 820-15 & 500-15
All this internet talk of catch cans. Would that impact the warranty at all? My gut says no but I’ve had a dealer try to tell me my aftermarket intake voided the warranty when my brake calipers failed at 15k.
I’m curious if I should get a catch can, especially if there is no harm in getting one. I commute in this rig in the winter and I only drive 2.5 miles each way. In the summer I hope to ride my bicycle.
No way.. no how am I installing one while the truck is under warranty.
Think about this for a minute. On our 2019/2020 Rangers the catch can manufacturers tie into a rubber vacuum line that is very short and then supply (2) 4 foot long rubber vacuum lines that go to / from the catch can. PCV valves open and close based on the amount of vacuum at the PCV valve. There is a pressure drop associated with those longer vacuum lines they supplied. Did they take that into account?
A guy over at the ranger5g.com site put a catch can on his truck. He then noticed the truck was getting a lot of gas in the oil. Every time he checked the oil dipstick, the oil level was higher and it wreaked of fuel. I suggested he remove the catch can... but he didn't. He takes it to the dealer... they have no idea what's going on.
Another guy posted photo's of what was in the catch can and said it was mostly fuel! You want those fuel vapors to get pulled through the system and piped back into the intake manifold... so those vapors will help clean the deposits off the valves!
The Mustang guys swear by the catch cans. But the motors in the Rangers are not identical, and there are specific differences.
The fact that the can collects "stuff" doesn't mean that "stuff" would have hurt anything if the can wasn't there.... in our Rangers....
If these catch can folks really wanted to convince us they would take two new 2019 Rangers, install a catch can on one Ranger, leave the other Ranger bone stock, and then drive the trucks, one following the other, for lets say 8,000 miles. Then take off the intake manifolds and compare the deposit build up on the intake valves.
You can't take some guy who has a catch cans word that it helps unless he pulled the intake manifold off, inspected the valves, then put on the catch can, drove the truck for a bunch of miles, then pull off the intake and inspect the valves again and saw a marked improvement.
Until some real world testing is done.... I'm not going to take their word for it.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Ask a VW owner If catch cans work. They do. And auto makers know this as well which is why pure direct injection is being phased out for dual injection. One injector sprays into the cylinder and then every so many cycles a second injector sprays on the intake to flush the intake valve. I have a catch can on a non direct injection engine and the stuff in that catch can is nasty. It's a 100% proven issue with direct injection not a myth. It's the pcv system that causes the problem. When you vent that moisture, oil, gas mix back into the intake its gross. But gasoline flushing past the valve cleans it off. A dry intake valve getting covered in that gunk its gonna be nasty. Been proven, it's a thing. The earth isnt flat, direct injection + pcv = dirty intake valves.
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
So you have installed a catch can on your 2019 Ranger that's under warranty .... right?
Nobody is saying intake deposits don't happen, the question is, on the new 2019 Ranger, is it enough of an issue that it will cause a problem. The Ranger motor is different than the Mustang and certainly different from a VW.
snoranger
Professional money waster
ASE Certified Tech
13,690
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I pulled an intake off a ‘17 F250 6.2l...
35445
A catch can wouldn’t hurt.
snoranger
ASE Certified Tech
13,690
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
sgtsandman
Aircraft Fuel Tank Diver
12,714
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Decide what you want but the carbon deposit issue on direct injection engines is an issue.
Different Ecoboost Engine but the same issue and this guy is a Ford Technician. Granted, just because he is a Ford Tech doesn't make his word gospel but he does go through the issue and what he has found on his own personal vehicle.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Has anyone taken the Rangers 2.3 engine apart to find/verify this kind of issue??
sgtsandman
12,714
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I don't think anyone has enough miles yet for it to make a difference at this point. All we have is what other people have found on their direct injection engines that have not been updated to direct injection and intake injection. With ones with the direct and intake injection have been produced to combat, if not eliminate the valve coking issue.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Fig. 5: EcoBoost intake valve deposit at 20,000 miles
(Below, is a portion of a article, written in 2018--Those of us that bought early-maybe we will get a "retrofit"????)
Larger, harder and more crusty GDI deposits often require preventive maintenance to prevent sputter, misfire, hesitation and loss of volumetric efficiency and power. It’s very important to keep reminding motorists that preventive maintenance can help avoid costly repairs down the road. Even drivers of low-mileage vehicles are at risk. Need proof? Check out Fig. 5, which is a tech’s borescope showing an EcoBoost intake valve deposit at only 20,000 miles.
Do dual fuel delivery systems eliminate the need for preventive maintenance? Certainly not — especially with deposit problems affecting both PFI and GDI engines.
The best way to fight engine deposits is to “deposit” preventive maintenance, to keep an engine functioning well and help customers avoid expensive repairs.
r1ch999999
33
Hollis, NH
Ford Mustang
So really at this point nobody has an answer if this 2.3 does this. Is the Mustang engine close enough to use that as a comparison?
sgtsandman
12,714
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
If I remember correctly, the Mustang version has a higher output and some of the configuration is a bit different because of the expected duty the engine is going to perform. I think the basic overall engine core is the same, just the accessories and how the computer controls it is different.
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
No. Similar, but different.
17,936
SW Iowa
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
What makes them different from every other DI engine?
Again, what makes it different than any other direct injection engine? :dunno:
According to the article below the Ranger motor is based on the Focus RS motor... but it's not the same, there are differences:
https://www.roadandtrack.com/car-shows/detroit-auto-show/a15840269/ford-focus-rs-ranger-engine/
