2011 Ranger XLT - Transfer case will not shift - DTC 1891-6F, 1867-2F
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Gents -
Been dealing with no 4x4 on the 2011 since last year.
As of now, both the transfer case motor and the 4x4 control module are new. Threw the 4x4 module in today, and still do not have 4wd.
ForScan is showing me two different error codes with old or new 4x4 modules:
P1867-6F - Transmission transfer case contact plate general circuit failure
P1891-2F - Transfer case contact plate ground return open circuit
......halp
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Should note, as soon as I clear the DTCs with either unit with 4scan, they pop right back up, even before I attempt to shift.
Disconnecting the battery (positive, kick on headlights to drain system) does nothing either.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Does the wiring and switch check good?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
No idea. Waiting on a second set of hands to test wiring next.
Protocol for testing switch? I have very little knowledge on this setup.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Hell, does anyone have the wiring diagram for it?
sgtsandman
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I can provide the diagram. Give me a bit to get them manual and scan the pages. As far as the switch goes, you'll probably have to pull the dash. Pulling the kick panel might give you access but I doubt it.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Switch comes out with the faceplate, so no big deal there, all the stuff is out already.
I guess at this point the last things it could be are wiring or the switch... maybe. No idea.
sgtsandman
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Or a broken ground somewhere underneath...
sgtsandman
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
These should get you going. The Battery Junction Box (Engine Bay Relay Box) and Smart Junction Box (Fuse Box) should be in your Owner's Manual.
70784
70785
70786
70787
70788
sgtsandman
Ham Radio Operator
12,706
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Give me a call if you still need someone to help. I can help you out.
CrabGuy
474
Sacramento, CA/Seal Rock, OR
2004-Bone stock
Ranger XLT
Why should I pay someone else to screw it up when I can screw it up myself for free?
Probably not so simple but I felt like a fool. I replaced both my shift motor and 4WD module and found out either the old module or shift motor kept blowing the 4WD fuse in the passenger kick panel. Replaced that fuse after the new parts and everything has worked fine since.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Checked both sides of both... have power across them.
Shit.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Ok, so a serious wtf... I have ground on both ground wires coming from the 4x4 module. So... qhy do neither of them sense ground?
Ran a jumper from the 4x4 motor to the frame as well and tried the switch... no difference.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Anyone know how the switch is supposed to read on a meter?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Pulled the switch apart, all intact I guess. Odd that the only pin I get an ohm reading from is the 2wd one.
No idea. This is driving me nuts.
This is why I prefer manual shit.
