2009 Ranger R8 Axle Door Code Clarification
JordK
Hello, new to the forums here, signed up to maybe provide some info on something.
From the research I have done, an R8 axle code on the door sticker indicates a gear ratio of 4.56. However, there are a few places that state the R8 simply means its a 4.10 with a Torsen LSD.
Many people I have seen have also said that R8 axles simply don't exist, either due to the 4.56 gears not coming from the factory or not at all.
So here is a picture to prove they at least exist: https://www.dropbox.com/s/jhvohs1o86ws7cr/IMAG0368.jpg
From a 2009 Ranger FX4 Off Road from Canada. I have not taken off the differential plate to see if it truly has the Torsen, but it absolutely is a 31 spline and 4.10 gears. Hopefully this helps some people with information.
JordK
My book says R8 is a 4.10 8.8, limited slip, 3600 GVW.
JordK
Yes, I have seen much fewer places that distinguish it as such on forums. Most the "charts" say 4.56. I think it might be true that R8 is, at least usually, a 4.10, not the mythical 4.56 which I don't think anyone has ever seen before on a stock truck.
Thanks for the input! Hoping this will clarify some information about the Ranger.
What book are you using?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Ford shop manuals I would be guessing, same as myself as we are Ford techs.
Here is what is listed for the 09 ranger
The following lists the gear ratios on axles.
  • 86 — 3.73 non-limited slip (7.5 inch)
  • 87 — 4.10 non-limited slip (7.5 inch)
  • 95 — 3.55 non-limited slip (8.8 inch)
  • 96 — 3.73 non-limited slip (8.8 inch)
  • 97 — 4.10 non-limited slip (8.8 inch)
  • R5 — 3.55 limited slip (8.8 inch)
  • R6 — 3.73 limited slip (8.8 inch)
  • R7 — 4.10 limited slip (8.8 inch) — 2,750 lb GVW
  • R8— 4.10 limited slip (8.8 inch) — 3,600 lb GVW
JordK
I wonder where the thought of the 4.56 gears came from. Unless it is something specially Canadian or something extremely rare... (Edit: Didn't notice you were from BC).
I guess till someone else comes along with proof otherwise, the R8 certainly is a 4.10, not a 4.56, at this point. Hopefully the people who made the charts can find this thread eventually.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Its not a Canadian thing, I just posted the table out of the 09 shop manual.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Also the R8 axle code is only listed for 08/09 model years.
JordK
This is an 09' Ranger, so that works at least. I think maybe it has more to do with the diff having a Torsen LSD than anything to do with the gear ratio?
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Torsen and 31 spline shafts/larger axle bearings (hence the higher GVW)
JordK
Alright, wonderful. Thank you for your help! This confirms most things here.
RDNX
wv
ford ranger FX4
Exactly my point, it says R8 is a
L/S 8.8"
4.56
Which this is absolutely not. Its an R8, but it has 4.10 gears, not 4.56. I think there is where the confusion stems from. People say the 4.56s don't exist (stock from dealer), and in conjunction, the R8 doesn't. At least one certainly does.
EXPLAIN THIS:
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
EXPLAIN THIS:
It's an axle.
