2009 ford ranger sport extended cab v6 4.0L rear wheel, automatic questions
dcorbb
Ontario
Ranger sport
hello just had a few questions i bought a ranger a year a go and its still in great shape ill post pictures in a bit but my oil changers place told me the transmission pan has a tiny tiny leak said nothing crazy but i want to make sure its okay, any one have experience with leaks like that and what should i look for or can do to help it? or just bring it to a mechanic basicly?
also i went and asked 4 different mechanics cause i got a oil change in the start of this year and they were trying to sell me on everything but he did show me the truck was lifted up and pulled a little on my front tires (rear wheel drive) and said the wheel bearings / ball joints need to be fully replaced but i bought my ranger at like 89000km its at 113000 now it was from a dealership not a private buyer and paid 15,000 with warranty, warranty helped pay for a new starter so far its in still great shape, canadian winter made it rust a tiny bit on bottom of doors but might replace that next year or i don't know how much it would cost for surface rust fixing on doors but anyways thanks for all the help
dcorbb
Ontario
Ranger sport
oops sorry meant to post this in help.
8,374
If its a small leak then just check Fluid level every month or so and when its time to change fluid and filter the new gasket should solve that leak problem
Its a gravity leak, there is no pressure inside the transmission pan, the gasket is there because the metal of transmission case and pan expanded when heated and then contract when cooled down again, and they expand and contract at different rates, same as metal valve covers do
So over time small leaks can happen
Well, lower ball joints do wear out that's where all the weight of the front of vehicle sits on
And you would usually replace upper ball joint when doing the lower, and while it can be a mileage thing they can also be worn out by just sitting for long periods because internal lube is not being spread around from use, so it sticks, you don't feel it, but the wear starts and then won't stop
Same for wheel bearings, can last high miles but sitting can cause seals to stick and wear starts
You WILL see uneven tire wear on the front when these get bad
