2001 Mercury Mountaineer
Memphis
Knoxville, IA
2.3
Hello, it's been awhile since I've been on here. I sold my Ranger and have been mad at myself ever since! I am looking at this above mentioned Mountaineer. It is for sale for $5,200 and has 107,000 miles. It seems in good shape, but I haven't seen it yet.
What are some things to look at? What are some trouble issues? Good vehicle? Bad vehicle? Thanks, Scott
Earl43P
38
Farmington, Pa
Ford F250 4WD
Memphis
Knoxville, IA
2.3
It is an 8cyl.
UrbanRedneckKid
17
Cass Co, Missouri
I love mine, it a 99 Eddie Bauer Explorer.
Other than the normal wear and tear, the only real problem is the Awd transfer case is junk.
There is a viscous coupling in the case that is known to go bad, and lock up. Makes it like driving around in 4hi all the time.
The engine is a tried and true 302, the transmission is an overkill 4r70w.
Mine has 206k mi on it and the case is just now locking up. So that one should have a ways yet. Make sure the front driveshaft is in it when you buy it, because that's how people hide a bad t-case to sell it.
The price does seem a little steep... I paid $2500 for mine, I haven't seen an Ex go for more than $4500, and the Mountys usually go cheaper.
Sent from my PG86100 using Tapatalk 2
Memphis
Knoxville, IA
2.3
How bad is the transfer case? Really expensive? I like to think ahead......
UrbanRedneckKid
17
Cass Co, Missouri
Basically you can't rebuild it reasonably, the coupling is $800 and impossible to find, and every case in the junkyard is wore out too.
There is a F150/Expedition case swap that will give you 2hi/4hi, but those cases are getting hard to find and requires driveshaft modification.
UrbanRedneckKid
17
Cass Co, Missouri
I believe most Mounty's had the 5.0. Kinda hard to find Expys with the V8, wasn't it?
No.
It's a very common engine for the 2nd gen Ex. I see them everywhere, and have at least 10 in our shop customer base.
When I bought mine I had 6 to choose from on Craigslist and only one was a Merc, but they all had 5.0s and there were a few more that were out of my price range.
Keep an eye out when you see a 2nd gen Ex, if it has the 5.0 it'll have a small V8 emblem in the middle of the front fender behind the tire. V6 trucks had no emblems there.
UrbanRedneckKid
17
Cass Co, Missouri
Here's mine.
FWIW... They tow like sh!t iii
Memphis
Knoxville, IA
2.3
Thanks so far, guys! I'm encouraged by what I've read. My main concern is, are these reliable? How is it going to hold up? Do they do really good in the snow? I've never had a 4WD before. The transfer case issue concerns me a little.
When I look at 'carcomplaints.com' and 'carsurvey.com' they seem to be a good vehicle, but when I check on the Ford Explorer they seem to be plagued with troubles. I'm a bit confused on that......
Thed
19
Raleigh, NC
The engine and transmission are both bulletproof. Transfer cases are what you want to look out for because of the previously-mentioned coupling issue. It won't make it un-drivable, you'd just always be in 4WD.
Memphis
Knoxville, IA
2.3
At worst that would burn more gas.....wear tires and suspension faster.....
UrbanRedneckKid
17
Cass Co, Missouri
Grenade front axle housings, strip cv axles, and ruin front driveshafts.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
My Brother had a 2001 Explorer with a bad viscous coupling. It grenaded 3 front axles before I figured out what it was. The coupling itself was around 400 dollars. At that point, we replaced the axle one last time (wrecking yard warrantied it) and he drove it slow to a dealer and traded it in. It was fine as long as he kept it under 40 mph. But anything over that caused so much heat that the oil would boil and blow out the vent.... then kaput. The best fix is to switch out the case for a manual 4406 out of an F150.
I had a 98 Mounty 5.0 and it ran absolutely flawless. They are awesome in the snow. The only thing that I traded it in for was fuel mileage. The person that has it now lives pretty close to me, so I still see it every now and again. I always want to say "You know that scratch on the rear passenger side door? I did that".
I would consider not being able to go on the freeway un-driveable. Also, it's an AWD - it has no 2WD. So if it's working correctly, you will still "always be in 4WD".
One last thing..... here is a GREAT little deal on the swap to a manual 4406 case like I mentioned: http://www.explorerforum.com/forums/showthread.php?t=166726
Memphis
Knoxville, IA
2.3
Ok, when I go look at this, how do I test the 4wd or AWD to make sure it's working properly? How do I make sure it's not stuck in 4HI? Thanks, Scott
