2.9L Oil Filter Upgrade?
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
System One or O'Berg
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
The FL1A is one of the biggest oil filters Ford used on gas engines, ever. How much upgrade do you need?
ALL OF IT
85_Ranger4x4
17,879
SW Iowa
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Nah. Glyptal.
Or. More filters to clog with glyptal.
But let me tell you.
That sh*t is ON THERE.
Rumor has it cannot sludge with it, and forum guys will swear oil comes out clean.
Wound up painting every single cast or bare steel surface oil touches, including sandblasting and painting inside of valve covers and oil pan to see if I can get vapors to condense.
Even did the back of the block facing the trans so less clutch fibers wind up stuck in there.
Only place I could not get to was the cam galley.
Ranger101
9
Richmond, Virginia
Ford Ranger XLT
If you don't mind using a remote oil filter adapter, you can use any size filter that you want. You can even mount it out if the way and where it gets some cooling.
Feel free to remind me, to take a some pics of mine, forward on the passenger side and getting airflow ..)
Gaz,
This is the reminder you requested to take some pictures of your remote oil filter adapter setup. Do you have an oil cooler in line with it or a thermostat in the adapter?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
gaz
661
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Ranger 101:
Yes pics today, thanks
It has both a thermo flow valve and a cooler.
gaz
661
Wa, Bremerton 98310
Here is the cooler location.
gaz
661
Wa, Bremerton 98310
Here is the thermo bypass valve loction.
I am having problems both getting pics from my phones memory and posting on location due to low bars. I will try again today.
Ranger101
9
Richmond, Virginia
Ford Ranger XLT
The thermo byass location photo didn’t come thru.
Is the cooler behind the grill a kit for the oil cooler or did you convert a transmission cooler for use as an oil cooler? I saw a tranny cooler conversion on YouTube.
If not, how where did you get both the adapter and cooler kit from? Looking forward to the pics. Thanks.
gaz
661
Wa, Bremerton 98310
Ranger101:
All 3 devices were sourced seperatly from Summit Racing:
The cooler is an Oil Cooler kit, I chose it because of the tubing size and passes. It wasn't much of a kit though, just the until, hose/clamps and 8 stopper zip strip devices but it worked.
The thermo valve came with the wrong size Barb's but I really though that it would help with engine warm up so I replaced them with the correct size. The remote oil filter adapter came with some hose and clamps.
gaz
661
Wa, Bremerton 98310
Thermal valve location.
gaz
661
Wa, Bremerton 98310
Remote oil filter and pluming through the frame.
Ranger101
9
Richmond, Virginia
Ford Ranger XLT
Gaz,
Thanks. The pics and insight are VERY helpful. I’m researching all three and have a feeling that all three will find there way to my 89. I’m going to spend time researching kits, cost, and location under the hood.
My goal is to have the ‘coolest’ oil ever! LOL
