2.9 misfiring and loosing spark randomly when warmed up
franklin2
1,768
Virginia
Bronco II
I would check codes if i had a check engine light, my gauge cluster never had it to begin with, my tps is fairly new since i had to replace it since it actually failed on me while driving but ill keep troubleshooting
You don't use the check engine light on these older trucks. You can use a testlight. Here's how to do it.
Paulos
210
North Carolina
1987 STX
im guessing the previous owners let it sit for awhile and the ethanol in the fuel may have gummed up the injectors..
That's what happened to mine. I drove the company truck for about a year while my Ranger mostly sat in the driveway. I've used LUCAS Ethanol Fuel Conditioner since replacing the injectors. It may be paranoia on my part, but I haven't had anymore issues.
Zapper
Yes i can afford this without "daddies money"
45
Buhl,ID
1986ish
ford ranger
2.294e+6 cubic millimeters
shot bushings?
235/75/r15
To send it or not to send it, that is the question.
Bird76Mojo
1,265
IL
How do you know it's not burning it? Especially since the 2.9 is notorious for cracking heads...
Think about it. It makes sense. Starts misfiring when warmed up and the coolant system is under pressure.. Two different 2.9's I had did the exact same thing and they both had cracked heads. In the exact same spot.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The shielding is common and the idm wiring to the pcm.... where it meets the coil and also splits to the tach.
Then there are actual board issues in the pcm...
Have had shitty tfi right out of the box too...and dizzy...
