We are in the process of ordering Duraspark stuff now, I just wish who ever had this thing before it showed up here hadn't chopped everything under the hood up as bad. I am kinda starting this project with no electronics at all. Alternator and starter is about all that is still there. Carb is from a much larger engine, but if it'll start, that is a step in the right direction.
Please tell me there is a choice for a rebuilt distributor besides Cardone ????
Thanks for your input
John
I haven't found one. And their idea of "rebuilt" is different from mine. I needed a distributor gear for a 2.9. Lots of listings, but no one had one. I broke a tooth on mine taking it off to replace the ignition pickup. So I went ahead and bought a "rebuilt" from the auto parts store, it was a Cardone. Installed it and ended up with more problems than I started with. So I took the rebuilt distributor back out, and being more careful tore it down. All that old black mucky grime was still inside the distributor bearings. The module hadn't been replaced. They hadn't even taken it apart. All they did was clean it up on the outside and sent it out the door.
I took and cleaned up everything, installed the new module I had purchased for the other distributor, lubed the bearings and put it all back together. Ran like a champ then. I paid close to $80 for that Cardone rebuilt distributor.
I too then bought a BII with the 2.8. It was running pretty bad, so I did the distributor swap to get rid of the computer system. I searched and searched, no matter who you deal with, it's always going to be a Cardone rebuild. So I had to do it and bought a 2.8 distributor for a 1979 Mustang II. It turned out to work fine. I believe we have to thank the parts changers in the world. If you get a distributor that didn;t have anything wrong with it in the first place, then when you buy it "rebuilt" then you will get a good distributor.
