2.0L ('83-'88) 2.3 Turbo Swap - Tire Change
judahd
Boise
2.0 (4 Cylinder)
Short time listener, first time caller - I have a stock 1985 2.0L, 2WD, manual, carb. Going to swap the engine, likely for a 2.3T Not looking to go bananas on HP, but probably more than necessary. I do not want to lift or lower the truck. I would like to improve the suspension for a better ride and potentially improve the brakes if that seemed necessary but that's it. However, I immediately need to change the tires out because they are questionable at best. Current tires are 205/75R14. Door calls for 185/75R14. What tires do I need to get? If I need a different tire, do I need to change out the wheels too? Personally I like the look but I also don't want to buy a whole new set of tires only to find out they're not a good fit for a souped up engine. Thank you!
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Tires don't matter too much on the engine, depends on your uses... what gear ratio is in the rear axle? On the drivers door there's a tag and will say axle at the bottom, what's the number under that?
It probably has 3.08:1 or 3.45:1 gears as they liked those in the '80's...
14" wheels fit on even the newest of TTB brakes (two piston calipers on '95-97) and the back doesn't matter unless you go with a disc brake explorer axle so whatever. Wider is going to be better but the stock wheels are only like 6" wide so they're a bit spongey when you go to 225 or wider...
judahd
Boise
2.0 (4 Cylinder)
I went to go look and I don’t see a ratio. Am I missing something? IMG_2229.jpeg
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Kinda, if you go HERE in the tech library it gives you a list of the axle codes from that sticker, you have code 84 which means 7.5" axle with 3.45 gears...
Apparently the transmission code 5 means a Toyo Koygo 5 speed so at least you have overdrive...
