2.3 Ranger... issue..?
Jerry0911
Indiana
Hello, I recently bought a 2011 ranger with a quirk. I was storing the truck for a friend and decided just to buy the thing because I didn't want it to sit any longer than it had. Its a Texas truck and I live in the salt belt, so a low mileage ranger with no rust was the closest ill ever get to a goldmine. 92k, 2.3L, 5mt 2WD. After driving it for a few days I noticed that it intermittently seems sluggish. I know the 2.3 isn't a powerhouse but this thing feels like its dragging weight, but only sometimes. I can feel it "pop" into power sometimes, at random, and then it feels great until I shift out. Almost like it cant keep a consistent fuel map. It also cranks for longer than usual on occasion, and when I throw it in neutral while rolling and hit the brakes, idle will drop to 300 rpm and then surge back and forth between 300-1000. When sitting at a stoplight on the brakes, it idles perfectly ay 750. No trouble accelerating (except low power) and steady driving I have felt it miss once or twice just at random. The worst part of this is that it never throws a CEL. CEL does work, but it hasn't triggered it while driving. Any tips?
Uncle Gump
Token Old Guy
13,469
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would suggest looking at the basics first.
Unsteady idle can be caused by a vacuum leak.
The rough starting and lack of power kinda sounds like fuel delivery issues. I would suggest testing fuel pressure before doing much else.
Jerry0911
Indiana
What would acceptable fuel pressure be in this instance?
8,370
Clean MAF sensor, once a year, its easy to do, once you have done it one time
The O2 sensor is the only sensor that has a time limit
It uses a chemical reaction to detect Oxygen in the exhaust, and the chemical gets used up
100k miles or 12 years, is when they should be changed
Yours are due, and new O2s pay for themselves over the next 100k miles or 12years in fuel savings
O2 data is how the computer sets the fuel map
1998-2011 Rangers used 55-65psi fuel pressure, there should be a test port on the engines fuel rail, its a schrader valve, like a tires air valve, works the same way
Running, idling, pressure should be between 55-65psi
Raise RPMs and hold them at 2,500(approx.), for at least a minute, if pressure is slowing dropping then fuel filter is dirty or fuel pump is weak
Shut off engine, pressure should hold above 25psi for MONTHS and MONTHS
If it slowly or quickly, drops to 0psi then fuel pump or regulator, in the gas tank, is leaking pressure
For now you can cycle key off and then on 3 times, this will restore lost pressure, then try to start engine
Uncle Gump
Token Old Guy
13,469
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
@RonD to the rescue... He has probably forgot more about these trucks then I could ever learn... he won't steer you wrong.
Jerry0911
Indiana
This is the kind of information I came here for, right on man thank you.
