YungICY
- Jul 19, 2013
- 1
- Ford
- Engine Size
- 2.3
I have an 85 2.3 that I rebuilt and converted to a Holley carb and among a bunch of the cork gaskets leaking I also have a vent tube coming off the oil fill cap that doesn’t have anywhere to route to do it just vents to atmosphere and adds to the leaking oil under the hood.
I have a pcv hose that comes from the lower part of the block, through a pcv valve and into the only vacuum port on my carb.
Can I plug the lower port coming out of block and just use the tube coming out of the oil cap? Any ill effects to doing this? Also would it be wise to run that routing with or without the pcv valve? It’s probably also relevant that I do have excessive blow by.
