1999 xlt ranger with a 2001 engine swap 4L
DrCox
Eugene Oregon
ford ranger xlt
i bought this truck a few years back and it treated me rather well other than (i am sure i am using wrong word, little black box that plugs into the wiring hardness) silenoid giving me issues with truck not starting unless it was played with in the wiring harness, not sure if it was the right fix but a friend just soldered some wires and it fixed that issue
fast forward a year or so and the truck was getting me to work and back with very little issues, well one day on the way home from work it felt like the entire truck was tugging like i was going uphill with a huge load but i wasn't i was barely going at a incline at all and the truck was slowing down, it eventually stopped and it ran perfect all the way home, the next morning i put it in reverse after warming it up and i heard this noise like i had just backed into someone, freaked out i get out of the truck and see nothing (funny part is that i actually got out and made sure nobody was behind me before hand) so i put it back in reserve and it moves only a few feet backwards and wont go any futher i put it in drive and it moves just about to where i normally park and its been sitting there for sadly 1+ year i have had several "mechanics" look at it nobody really ever gives me much to go on, the most recent guy put it on jackstands and did a few tests i didnt really understand and he claims the rear diff needs repaired/replaced.
well if this is the wrong section i am sorry first time user just signed up today found this site on duckduckgo.com search ty for any help!
DrCox
Eugene Oregon
ford ranger xlt
darn no replys well it turns out (i think) i need to get a new rear end,
1999 Ford Ranger Rear Axle Assembly
XLT, 4.0, 4X4 8.8 RING GEAR, 9 BRAKES, 3.73 RATIO
the prices seem all over the place for these tried several local wrecking yards only to find out most of them are all connected to same business B & R, anyone have what they think is a fair price for one of these?
8,372
Welcome to TRS :)
Sorry no one responded
Yes, could be the rear axle, did you ever notice a HUMMMM coming from the rear will driving before this happened?
Yes, you can use a 1993-2009 Ranger rear axle, so the one listed is fine
You can check on your drivers door label, back edge, for your AXLE code, then go here: https://www.therangerstation.com/tech_library/axle_codes.shtml
This AXLE code will tell you what it has now
I ASSUME you have a 2WD not a 4x4, if you have a 4x4 then you MUST match ratio, i.e. 3.55, 3.73 or 4.10
If 2WD you can use what you want, speedo will still be correct because its a 1998-2000 Ranger
Go to car-parts: http://www.car-part.com/
Enter your info and see what the going rate is in your area
1999 Ford Ranger, axle assembly rear w/housing
Then select the type you have now from the list
Prices vary by area, also miles on the used part when its part of the drivetrain
DrCox
Eugene Oregon
ford ranger xlt
yah its a 4x4, but you know i do think there was a hum sound here and there, with that said i put it on jackstands and when i move the tires it makes some messed up sounds, ty for the reply ill look into this
DrCox
Eugene Oregon
ford ranger xlt
another thing that makes me thing you might be right about the axel the left back tire if you put one and on the top and one on the bottom the tire its self can wobble back n fourth and that cant be normal
8,372
Yes, reads like rear differential has failed in some way
Because its a 4x4 you need to match rear axle ratio and front axle ratio, so get the AXLE Code
Any rear axle from a 1993-2009 Ranger with matching ratio will work and fit, you have a 8.8" but a 7.5" will work
9" or 10" brakes also don't matter, 10" would be better but 9" work just fine
L/S, limited slip are best to find/use but also not required
The RATIO is the big deal because you have a 4x4
DrCox
Eugene Oregon
ford ranger xlt
damn this is really helpful yah 3.73 ratio for sure, ty for your help
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If it's not a daily driver that you need done immediately I'd hold out for a L/S axle. Or even a 2010-2011 so you get the disc rear brakes.
DrCox
Eugene Oregon
ford ranger xlt
ill def call around town see if i can find a disc break unit that sound like a nice upgrade if i can get it
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
It's a rare option being the last 2 years of the ranger. But if you find one, why not.
8,372
Well.............rear discs do require more work, i.e. brake lines and brake cables
