1997 XLT 4x4 Trouble
8,370
As the motor turns the contact plate(and transfer case shift rod) the GEM can keep track of its progress
2H>edge1>2h-4h>edge2>4h
Each is a "point" on the rotation, the edges are "waypoints" as is the 2h-4h
2h is the start and 4h is the destination, the waypoints tell the GEM things are going OK
So its just a measure of control so if GEM doesn't "see" one of the "points" it will know something is wrong and stop the motor
PeteFleck
Haida Gwaii
So according to the table.. my contacts are currently in the Edge 4 position, but the truck is in 2WD.. so I need to reposition the plate on top of the motor so that the contacts read correct for the 2WD position?
8,370
So right now A B and C are shorted to yellow/white?
I would pull out the shift motor again and then manually power the shift motor to confirm all 9 settings
Because the shift motor shouldn't go on to the transfer case shift rod in the edge 4 position if transfer case is in 2h
I just found this one, but it just has the 2h, 4h, and 4l, no edges
And it is different than the first one??
So maybe Ford changed the pattern at some point
The first one was for the 1983-1994 4x4 controller modules
The one above didn't list any years, but the shift motor from any year seemed to work on any other year so I am a bit confused
As far as I know a 1990 shift motor would work in a 2005 vehicle, but maybe it doesn't
PeteFleck
Haida Gwaii
It is very confusing! I’ll do some more testing tomorrow and let you know what I find.
Cheers Ron!
8,370
Yes, it is
In 1997(well 1995-2000) most common 4x4 issue with flashing 4WD light would be
blown fuse
failing shift motor
Bad dual relay box, don't hear a "click" behind radio
Bad GEM(4x4 controller), also don't hear a "click" behind radio
Auto hubs or PVH can also fail but.....no flashing light, transfer case shifts fine but front wheels don't lock
PeteFleck
Haida Gwaii
Hey Ron..
Going through that list..
I know it is not a fuse, I’ve double and triple checked
I know its not the relay.. I’ve tested with 9V battery, and I can hear it clicking away
The GEM seems to be functioning.. clicking behind radio
I have manual locking hubs
But the shift motor was what I suspected initially, ordered a new one and have had question marks over it since it arrived.. extremely tight on the shaft, and came out of a suspect looking box??
I will pull it out again tomorrow and probably try and manouvre the contact plate so it reads as per the table.. will let you know how I get on. I also contacted the parts store and had them get another shift motor on it’s way up here under warranty.
Thanks again for all your help! I think we will eventually get to the bottom of this!
Best,
Pete
8,370
Yes, there shouldn't be any surprises in Rangers electric 4x4 system, just has the 4 parts
dash switch
GEM
Dual relay
Shift motor
1983-1994 just had 3 parts as did 2001-2011, they didn't have the external dual relay box, and used a 4x4 controller instead of Body computer(GEM)
PeteFleck
Haida Gwaii
Evening Ron,
It’s over! The sleepless nights can stop!
I warrantied the ‘new’ shift motor I had bought and the replacement arrived today... plugged it in, turned the switch and bam.. I’m cruising in 4x4 again!
What a relief. I’ve learned a lesson or two over the course of this ordeal, most importantly never to assume something that is a ‘new’ part is a good part.
Thank you so much for all your help and your incredibly patient responses to my endless queries over the past month. It is hugely appreciated.
Until the next time & best of the season to you,
Pete
8,370
Good work (y)
Thanks for the update and "the FIX"
PeteFleck
Haida Gwaii
Morning Ron.. on an unrelated topic.. two questions.. my Ranger should be OBD2 compliant? Correct? If so, do you have a particular brand/model of scan tool you would recommend?
Thanks in advance,
Pete
8,370
I had, and still have, a mini elm327 for quite a few years, Bluetooth reader, gets codes, and clears codes, no complaints, free Torque Lite APP worked fine, never needed the $5 Torque Pro APP
But recently got a Bluedriver because it can also read transmission codes and "most" ABS codes, which the elm327 couldn't
Worked fine but only used it a few times
Also got an extension cable with the elm327 which I have needed to use a few times as some vehicles OBD2 plugs were in panel openings that were to tight for the bluetooth unit
