1997 ford ranger 2.3l 5 speed clutch pedal assembly question
swift700xx
15
Florida
Hey everyone I have a 97 ranger 2.3l 5 speed rwd with 31 psi in front right tire. The question I have is does the brake always go in when going to shift? Iv never owned a ranger before so not 100 percent sure if it was designed like that or not but when I press the clutch all the way to the floor the brake pushes in as well during the last 1/2 to 1 in on the depression. Also my brake pedal is sticking just ever so slightly and I have to pull it up just a little bit to get the lights to come off when I park it. I dont know if its time to replace the assembly or if there is a simple fix like a shot of pb blaster or something. Any help is appreciated and Thank you in advanced.
scotts90ranger
4,533
Dayton Oregon
2.3 Turbo
That isn't normal, I wouldn't use PB as there's too many solvents in it for that kind of thing but WD40 or something would be better... it's TIGHT up in that area to look into but it's only 4-5 bolts holding the seat in (4 for the seat and one for the seatbelt...) which would give you way more room...
There's a couple bushings on the pivot shaft that are probably dry and or rusted, I don't remember which one pivots on which but it's in there somewhere...
swift700xx
15
Florida
Ok awesome thank you. I wonder if I can just find the bushings instead of the whole assembly
RobbieD
2.9l Mafia
3,587
Georgia
Dorman has a kit in their "Help" packaging. I used their part # 14041 to re-bushing the pedals in my '90 Bronco II. You can check the application for your year on their website.
swift700xx
15
Florida
Thank you RobbieD. I am heading there right now to check them out.
