1997 Ford explorer bucking and jumping when accelerating
billwilliams
6
Phx az
Ford ranger XLT
Yes I have a 1997 Ford ranger XLT 2 wheel drive on acceleration at bucks and jumps and will not accelerate more than 20 miles an hour I've changed all the sensors I've done EGR valve I've done the coils the coil packs the plugs plug wires and still just jumps and bucks when I accelerate on it anybody has any ideas
franklin2
1,767
Virginia
Check your fuel pressure while driving.
scotts90ranger
4,411
Dayton Oregon
2.3 Turbo
Parts cannon method is hard to diagnose, anymore new parts doesn't mean good parts...
I would look pretty good for vacuum leaks too, MAF systems really care about that. Also, the main fuel pressure that matters can be read with the engine off, just key on and let the pump cycle and it should go to the regulator pressure (don't remember what it should be). Also, pull the vacuum hose off the pressure regulator and see if there's fuel there since there shouldn't be any. I would also suggest connecting to the engine with an OBD II reader and watch the fuel trim values as you drive if possible
billwilliams
6
Phx az
Ford ranger XLT
Checked while parked but can't get it to high rpm to drive it thank you
Thank u very much I think I mite of found problem but can't see it that well here at night and I don't feel like pulling out drop lights I'll check in the morning it seems like the fuel cut off switch that's under the dash is bad and it's cutting it off but I'll find out in the morning thank you for your advice I appreciate everything
8,372
30-40psi is running fuel pressure in 1997 and earlier Ranger(or Explorer)
+1 on MAF sensor, but CLEAN IT, don't replace it, common cause of bucking in the 4.0l vehicles is dirty MAF sensor
Change fuel filter, every 5 years
Put a vacuum gauge on the intake, start engine, should see 18-21" of vacuum
Raise RPMs a bit and hold it there, if vacuum starts to drop you have a Clogged Exhaust, air(exhaust) can't get out so new air with fuel can't get in, so limited RPM and bucking
Vacuum gauge is maybe $30 and one of the best tools to diagnose a running gasoline engine
Is the CEL(check engine light) on?
You can get a OBDII Bluetooth code reader for $15
It will tell you if a sensor is out of range, not bad just out of range, so NEVER EVER change sensors(except O2s) unless you get a CEL and code, AND you test the sensor first :)
Just a heads up
My 1994 4.0l has over 400k and all original sensors, except O2s, they wear out after 12 years, only sensors that do
Not lucky just most sensors never wear out
95% of DIY sensor changes were not bad, but the one that gets me the most are 60% of Pro-Mechanic sensor changes were not bad, lol, but they still charge you for the new sensor you didn't need
billwilliams
6
Phx az
Ford ranger XLT
Just a heads up
I appreciate the heads up you have a great weekend sir
billwilliams
6
Phx az
Ford ranger XLT
I appreciate the heads up and thank you have a great weekend
JoshT
1,782
Macon/Fort Valley, GA
I hate to even suggest this, but what does your radiator/coolant look like? Last few times (yes, it was a few times) my truck acted like that was due to failed headgasket. Biggest symptom prior to the bucking/jumping was the dirty coolant. After installing a different engine I haven't had another problem.
Probably not your problem, but if all else fails...
billwilliams
6
Phx az
Ford ranger XLT
Thank u about ready to pull motor and get a good look at it
rusty ol ranger
2.9 Mafia-Don
7,584
Michigan
177 CID
Whens the last time it had a fuel filter?
2011Supercab
469
Washington
Toyota Tacoma
Always a good idea to post your engine size in each new thread when having engine problems
You have another thread saying you have a 2.3.
Very possible the timing belt has slipped.
rusty ol ranger
2.9 Mafia-Don
7,584
Michigan
177 CID
The title says explorer but the post says ranger....
Im lost.
scotts90ranger
4,411
Dayton Oregon
2.3 Turbo
Probably like me and has multiples... just registered vehicles I have two Rangers and two Explorers... when I ordered hood struts for the Explorers I ordered two sets, the company messaged me making sure I meant to order two sets :). That's the assumption I made anyway...
JoshT
1,782
Pretty extreme measure for diagnosing and fixing a problem. If you suspect that I could have been right about the gasket, it would be a lot easier to rent a compression tester from the auto parts store. If it is a 2.3 It's probably not difficult to yank the motor, but I would still want to do more diagnosis in the vehicle before pulling it.
