jhart92
- Jul 31, 2016
- 0
- Ford
Had exhaust problems on my 96 4x4 Extended Cab 3.0L Manual ranger so i decided to try and bring over the upper intake manifold and exhaust manifold from a 1999 flex fuel 2wd ranger sport i had in the yard. got the exhaust manifold and upper intake to bolt up - had to get a little creative with the egr sensor placement and brought over the egr from the 99 but now the truck idles at 3500~3800rpm. checked for vac leaks, changed intake gaskets, cleaned the everything with maf cleaner, swapped icv, swapped pcv, swapped maf, and done just about everything i can think of while unplugging the battery each time. the only way i get a difference is by unplugging the maf - idle drops to about 900-1100 and runs rough. anyone have any ideas as to how this is happening would be greatly appreciated! it's my daily driver these days for various reasons and im deep enough into this project where swapping intakes again would be highly inconvenient. only difference i was able to spot was the evap system has a vac line going to it so i capped that off when i brought over the vac lines.
