firebat45
- Mar 30, 2010
- 0
- Mazda
I decided to post this here as well. I know SHO motors very well but I'm still new to Rangers, so this forum will probably be more help than the SHO forum.
I picked up a B3000 with a screwed motor, ripped it out and trashed it. I've always wanted to put a SHO into a Ranger, and I could use a parts hauler. The rest of the truck is in very decent shape, interior is great, just needs a new motor.
It's 2WD, 5 speed, completely stock. I'd like to keep it looking stock for now, no lifts or lowering in the plans.
I've got a 3.2 and a 3.0 SHO motor, either could go in. I'm leaning towards the 3.0 because this is not my project car (my SHO is) and it doesn't need a ton of power. It's still going to be heaps more than the Vulcan ever had. I do prefer the single accessory belt that the 3.2 has though, so we'll see.
I've already got all the clutch/flywheel problems sorted out from my other car (RWD Taurus).
The main issue I can see right now is that the SHO heads hang over the rear of the block about 3-4 inches, due to the DOHC and the timing chains. The Vulcan is pretty much flush, and there's not 3-4 inches of room between the Vulcan and the firewall. Width, height, and length all seem to be fine, I'd just like the engine to be shifted forward 2-4 inches. Can I just move the tranny crossmember forward 2-4 inches, lengthen driveshaft, bend shifter a bit more, and be done with it? Does anyone have a different solution?
As for lengthening the driveshaft, is there another vehicle I can get one from? I remember when I was figuring out what I needed for my Taurus, I found a chart listing lengths, and a Mark VIII shaft was perfect. I think I've read something about an 8.8 Explorer swap needing a 1.5" shorter driveshaft, if I move the crossmember/tranny that far forward and swap to Explorer rear, I should be good, right? Being able to use the Mark VIII shaft or a P71 shaft would be nice.
Here's some pics of a spare SHO block bolted to the tranny. There's TONS of room in front of the motor, the SHO engine is actually shorter than the Vulcan, it has a much more compact accessory setup. I'll be going with an electric fan on the rad (what works well?). No AC on this truck, not needed up in Canada.
Any thoughts or insights would be great. Thanks!
![](http://i23.photobucket.com/albums/b377/fire45bat/SHORanger/2010-03-22222314.jpg)
![](http://i23.photobucket.com/albums/b377/fire45bat/SHORanger/2010-03-22222326.jpg)
![](http://i23.photobucket.com/albums/b377/fire45bat/SHORanger/2010-03-22222339.jpg)
![](http://i23.photobucket.com/albums/b377/fire45bat/SHORanger/2010-03-22222600.jpg)
![](http://i23.photobucket.com/albums/b377/fire45bat/SHORanger/2010-03-22222709.jpg)
